Question about Toshiba Satellite A75-S211 Notebook
Windows will not load in any mode!! Crashed after I shut it down to restart.
Please help if you can thanks!
  • stardar Aug 28, 2008
    If I have to reformat the hard drive and install a new operating system how exactly do I go about THAT?
    Sergeant:
  • 264 Answers
The operating system is corrupted, you will have to arrange and disk for windows using which you may repair the same.
After booting from the cd.
Press "Enter" to set up XP.
Press "R" to repair the current installations of windows.
Note * I have given the solution assuming that you are using the win XP
All the best
Regards
Sammy
Posted on Aug 28, 2008
    Genius:
  • 2,028 Answers
I imagine this is in a continuous loop back to the black screen asking how you want to start, safe mode, normal, etc....
A majority of the time this is due to a failed hard drive, but it could also be a corrupt operating system due to a virus. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, the reformat the hard drive and install a new operating system. If the hard drive will not format or you have any problems during or after the install, then the hard drive has failed and will need replaced.
  • Ryan Rogers
    Ryan Rogers Aug 28, 2008
    I'm going to elaborate on Sammy's solution, because if you press R in the wrong repair section it's just going to confuse the hell out of you.
    At start up, you need to go into the boot menu, or go into the bios and set the CD drive to boot before the hard drive. Once you have booted from your recovery or operating system disc, then you will need to press enter to set up Windows. You will come to a screen that you can press R to repair using the recovery console, this is not the repair section you want, press Esc to continue the setup. It will then search for existing operating systems, once it has found the operating system then it will give you another prompt to press R for the repair, this is the repair section you want. Press R and let it run through he process. This where, if the repair doesn't take, you run this process again, but instead of pressing R, you want to delete the partition which will consist of pressing D, then enter, then L to confirm the deletion. Then you can set up Windows on the blank partition. I know this seems complicated, but it's not really all that bad. If you get stuck, just holler at me through the ask me section by my name.
Studio 17 laptop stalled during uploading of a music cd into ITune libray. Manual shut down and reboot resulted in stalling of reboot process at 3/4 of the status bar with only the dell logo on black...
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 16, 2011 | Dell Studio 17 Laptop
When I load my Toshiba Satellite L305D-S3958 It loads up saying it didn't shut down successfully. I tried all the modes from safe mode, safe mode with networking, safe mode with command prompt, and Star...
I hope that you have a goood back-up of file. Getting blue screen error is a fatal OS problem. You need to re-install windows.You need to get the CD that came with your computer or the operating system disc you used to install the windows. Insert the disc on the CD-DVD drive and restart your computer. Watch for a Press any key to boot from CD or DVD... message. Installation will start. Good Luck!
Mar 14, 2011 | Toshiba Satellite L305D-S5938 Laptop
I had a btand new 2011 quickbooks running on my computer then after a week it crashed. I can't open it and it gives me many error messages when I try to reinstall it. I have a 64-bit computer that has...
Hi there !
For some reasons computer can crashed because some corrupted, missing files, virus program or faulty driver installed. Faulty installed drivers or multiple drivers installed with the same drivers can crashed your computer. Running on Safe mode will remove mulltiple same drivers in your computer and it will run on fresh install driver when loading to normal mode.
I suggest to run your computer on safe mode.
To run on safe mode, just restart your computer and press F8 to run on safe mode. After going to windows setting, restart your computer again. Check if this solve your problem.
I hope it helps you and thank you for using FixYa!
Jan 09, 2011 | Computers & Internet
I got s blue screen today and it shut down b4 i could write down the code it gave what are the most common causes
corrupt HD and OS....reformat HD and install OS, boot from CD rom after inserting the WinXP disk
Feb 19, 2010 | Compaq Presario CQ50-215NR Notebook
Load up acer and screen black with arrow cursor only thing that works
registry or some Windows DLL files r corrupt...
try this..
restart, before u get the Windows screen press F8...
choose option load in Safe Mode
if Safe Mode loads and u get the desktop, try downloading Tuneup Utility from internet, install that and clean ur registry
then shut down and restart....
let it load in Normal mode....
let me know if that works else we can work some other solution
Dec 20, 2009 | Computers & Internet
Having Trouble Starting
Enter Safe Mode with Networking.
Update Video drivers.
Restart the system in normal mode and if still no go then you have to reinstall Vista from CD's.
Sep 25, 2008 | Toshiba Satellite A305-S6834 Notebook
After i load ssp2 my computer does not open window program
What is 2.2 frame?
Do you mean .Net framwork 2.2 update from microsoft?
Press & hold the power on button on the E-Machine. That will shut down the PC. Unplug the power cord from the power supply. Wait a minute. Re-connect the power cord to you're PC & press the power button on you're PC. Windows should start & may run check disk before loading windows. Continue updating windows through windows update service. There are more
.Net framwork updates. If you're system continues to run restarting shut it down as before. This time when you start up the PC start pressing the F5 key every two seconds. Windows Advanced Option Menu will load. Choose Safe mode. Open control panel, open add/remove programs. At the top of the window & slightly to the right of the Add or Remove Programs windows is a box next to Show Updates. Left click in the box. Scroll down & find .Net framwork 2.2 & uninstall it. Close all opened windows & restart the PC.
Continue to update you're windows.
Please let me know if this has helped.
Good Luck!
Mike
May 08, 2008 | E-Machines eMachines Desktop PC
My laptop crashed, a little help please!
login to the safe mode and re-set back to what u had set before.
Keep Pressing F8 when restart your computer to go to Safe Mode
Apr 13, 2008 | Acer Aspire 5610-4648 Notebook
Computer shut down ..wont restart
what has happened is your hard drive as failed and that is why it shut down and then gave the unmountable boot volume. You could try repairing windows using your XP cd but it's a new hard drive i recon.
Oct 05, 2007 | Compaq Presario M2000 Notebook
Toshiba Satellite A75-S211 Notebook Logo
153 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
