Question about Pentax *ist DS Digital Camera
Beginners question : Autofocus
I've received my IST Ds, and boy am I happy :) Coupled with my Sigma 18-200 it's just a fine do it all, and with my F 1.7, it seems more than capable at doing nice portraits. Obviously I have tons of things to discover, but right now I'm just wondering about one simple thing : On my bridge, mid pressing the shooter button started the autofocus. Then you could keep it mid pressed till you shooted. yes same. BUT, when you had pressed, if you came back to mid pressing without fully releasing, it would keep your set focus. very useful for portraits when you wanted to shoot fast without using a (too) rapid shooting mode. And without going manual (I'd rather not for the time being. And with that solution, if the subject moves, I can just autofocus again pretty fast). Any clue about how to do that ? Possible at all ? Apart from that I noticed that it seems to underexpose quite a lot, so I set it at +1. And that indoor photos need a custom white balance, otherwise they just turn out very yellow. And the autofocus is fine, even at low light. Well, that's all for now, I need to dive into the manual.
    Master:
  • 542 Answers
You can always do it the other way around, then - program the "OK" button to do your focusing. Then you take repeated shots on the same focus without hitting "OK" again. Of course, then you have to remember to actually use it when appropriate. But I could imagine developing that habit doing studio work. FWIW, though, switching to manual in these cases it quite easy - the button is quite easy to find. Take one picture auto, then switch to manual to take the others. Also, even if you leave autofocus enables and don't do *anything* special, I think you'll find that re-focusing on a subject that is already in focus is close to instantaneous.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
In the custom settings, you can program the "ok" button of the 4-way controller to disable AF. It's kind of a handy little trick. It's called "Ok button when shooting" or something.
Pentax MZ-60
have you tried cleaning the lens contacts with soft cloth?
ifnot do that.
is there no problem with out the lens in there?
Sep 18, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Will a Nikon Sigma 70-210 work on my nikon D60??
Assuming the lens has a Nikon mount, then it will fit and work on the D60. Sigma makes lenses for a variety of cameras; a lens with a Canon mount, for example, will not fit onto a Nikon camera. However, the 70-210 is a rather old lens. Unless it specifies "HSM" it will not autofocus on the D60. The D60 does not have an autofocus motor, relying on the lens to have one. Nikon calls such lenses "AF-S" while Sigma designates theirs "HSM".
Feb 03, 2011 | Nikon Sigma 70-210 F4-5.6 55MM AutoFocus...
I have the sigma 70-300mmD i just bought for my nikon D40 and i am having trouble with the auto focus. it will not autofocus can anyone tell me what i am doing wrong and or where i can download the...
The Nikon D40 does not have an autofocus motor, relying on the lens having one. This Sigma lens does not have such a motor, relying on the camera having one. Nikon designates lenses with an autofocus motor AF-S, Sigma calls theirs HSM.
Dec 17, 2010 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
Oct 14, 2009 | Sigma 70-300mm f/4-5.6 DG Lens
*IST DS autofocus
Try using another lens, if this solves the problem you have a lens problem. If not the camera is the problem.
Jul 03, 2009 | Pentax *ist D Digital Camera
Pentax *ist DS digital SLR Autofocus problem
Being an SLR camera, you should try another lens. It may be a servo fault in the lens. If the lens is okay, then it can be anything in the lens sensing, lens control drive circuits, and or lens to camera interface area. This would have to be properly diagnosed and serviced.
Jerry G.
Oct 11, 2008 | Pentax *ist DS Digital Camera
Why is my *ist DS eating my SD cards?!
I've used Sandisk Ultra II 512M cards, a PQI 1G and a Transcend 1G card (all high speed rated) in the *istDS. I've done about 1500 exposures now, many RAW, and have done several rounds of upload to my computer. No problems at all. These same cards work flawlessly in a Panasonic FZ10 as well. Either you have had a bit of bad luck, two defective SD cards in a row, or have a *istDS with a stuck or bad memory card controller. Try using the Reset command in the Set Up Menu, see if that helps. BTW, always format SD cards with the camera once before you start using them.
Sep 13, 2005 | Pentax *ist DS Digital Camera
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Pentax *ist DS Digital Camera Logo
44 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
