Question about Lands Phones
I have a Verizon XV 6800 that used to sync with our Exchange Server. Now I am getting an error message 80070002 Sunchronization could not be completed. Try again later. I have been trying for three days!
  • 3 more comments
  • jbrickman Aug 28, 2008
    I don't even understand the advice I received.
    I'm sorry but I do not understand your solution. Am I supposed to make changes to the registry keys as you described? I am not at all sure where to even begin.
    I just completed updating my phone and the problem still exists
    My PC Monitor settings on the phone are the same as on my PC, including connect to the Exchange Mailbox using HTTP and the HTTP connection settings are the same on both the phone and the PC. I do see the arrows going around when I try to sync
    I do not know yet - I will contact our server tech support people.
    Master:
  • 521 Answers
Create this folder and it will install
c:\windows\system32\logfiles
create a folder called firewall and the hotfix will install
c:\windows\system32\logfiles\firewall
This fixes it!! YIPPEE worked on 3 PC's for me all versions
Tip: Temporarily disable real-time protection by your anti-virus and/or
anti-spyware applications (e.g., CounterSpy, Spysweeper, Spybot, AVG
Anti-Spyware) and/or any third-party firewall (e.g., ZA) before attempting
to install the update(s).
Also see the Known Issues section of http://support.microsoft.com/kb/935807;
Using the appropriate resolution Method in 935807 /may/ allow the other two
updates to install. To download/install the other two updates install
manually, see http://support.microsoft.com/kb/933928 and
http://support.microsoft.com/kb/936357
Start a free Windows Update support incident request:
https://support.microsoft.com/oas/de...spx?gprid=6527
Customers in the U.S. and Canada can receive technical support from
Microsoft Product Support Services at 1-866-PCSAFETY. There is no-charge for
support calls that are associated with security updates. When you call,
clearly state that your problem is related to a Security Update and cite the
update's KB number (e.g., KB931678).
In other countries, see
http://support.microsoft.com/default...r=securityhome > "No-Charge
Support...for virus and other security-related" issues in right-hand menu
for localized contact information.
For more information about how to contact Microsoft for support issues,
visit the International Support Web site:
https://support.microsoft.com/common/international.aspx
please dorate the solution.sir.thanks.
Posted on Aug 28, 2008
    Genius:
  • 1,268 Answers
There's a restriction on the server or something like Access Policy. You may need to enter the MAC Address or IP Address of the device to sync with the server. Check with your network admin if there's MAC Filtering Policy or Firewall Rules before you can add any device on the network.
    Scholar:
  • 163 Answers
  • Elias Mavropoulos
    Elias Mavropoulos Aug 28, 2008
    " I was able to synch up fine with this
    server using PPC 2003 and ActiveSync 3.8 "
  • Lands Phones Master
  • 6,487 Answers
This error means that the PC Monitor was unable to establish or complete communication with the Wireless Sync server. To troubleshoot, first verify your proxy settings and also verify that the Monitor is able to connect to the Internet.
Verify the Proxy Information for the Windows user account:
  • Open Internet Explorer and go to Tools-Internet Options, Connection Tab- LAN Settings.
  • Verify that those settings match what is in PC Monitor. If “Automatically Detect” is selected then no changes are required to the PC Monitor. If “Use a Proxy Server for your LAN” is checked then copy those settings and enter them into the PC Monitor.
Verify that the PC Monitor is able to connect to the Internet:
  • Log into the Wireless Sync WebPIM. Go to View and select Activity Logs. You are looking to see if any connection is made to our servers from your Monitor. If so then you know they are getting outside the firewall.
  • Alternatively, when the PC Monitor does its first initialization for a user, do you see blue arrows going in a circle during the initial first time sync? If so, then the Monitor is able to communicate with the Wireless Sync server. If you don’t, then it is not going outside the firewall. If it’s not going outside the network, you will have to troubleshoot your firewall timeout policy and the amount of simultaneous connections that can be made through the firewall. Also, check your company policy for this type of software to transmit large chunks of data through the firewall.
Hope that helps........
  • Mark Gil
    Mark Gil Aug 28, 2008
    If that's the case you may need to contact your server because something is blocking the completion of the sync to the exchange server, it can be a security policy or firewall that is causing it...
    Genius:
  • 2,028 Answers
You might try updating the phone. I believe that with Verizon you dial *28, but I'm not 100% sure. Changed my service, and it's been a while since I had Verizon.
    Master:
  • 848 Answers
For a start you'll need to change one of your computername declarations to regcomputername (the bit where you Dim them - you've done the same one twice). As for your problem, replace hklm with HKEY_LOCAL_MACHINE and it should work
option explicit
dim objshell
dim regactivecomputername, computername, reghostname
dim activecomputername, regcomputername, hostname
regactivecomputername = "HKEY_LOCAL_MACHINE\system\currentcontrolset\control\" & _
"computername\activecomputername\computername"
regcomputername = "HKEY_LOCAL_MACHINE\system\currentcontrolset\control\" & _
"computername\computername\computername"
reghostname = "HKEY_LOCAL_MACHINE\system\currentcontrolset\services\tcpip\parameters\hostname"
set objshell = createobject("wscript.shell")
activecomputername = objshell.regread(regactivecomputername)
computername = objshell.regread(regcomputername)
hostname = objshell.regread(reghostname)
wscript.echo activecomputername & " is the active computer name"
wscript.echo computername & " is the computer name"
wscript.echo hostname & " is the host name"
  • 83 Answers
The Driver Has Been Deleted From Your Pc
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
Fix corupt messages exchange 2010 mailbox
I would say try moving users mailbox to see if that would help if not then no other option than to Restore from backup.
If doesn't help, look here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/exchange-server/734-repair-exchange-priv1-pub1-edb
Or: Exchange Server Repair Kit is an absolute must-have for any software development professional working with MS SQL databases.
For more information: http://www.exchangeserver.repair/
Dec 21, 2014 | Microsoft Exchange Server for PC
Email problems: error code 0x800CCC0F,
When you use Microsoft Outlook Express to send and receive mail to a Post Office Protocol 3 (POP3) or Internet Message Access Protocol (IMAP) server running Exchange 2000 Server or Exchange Server 2003, you may receive the following error message. Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity.
Sep 29, 2011 | Microsoft Internet Explorer 7
ActiveSync Not Working
it might be trying to configure a microsoft exchange sync thats why its giving you that message you may want to try and uninstall activesync and download the lastest verizon 4.5. during install do not click on check box that says connect to exchange server and try to sync again, should get you taken care of,
Apr 06, 2009 | Motorola Mobility Q9m Smartphone
Microsoft outlook on my verizon HTC SMT5800
Unless you are trying to sync with another Microsoft Exchange Server (say at your new Job) or you are running an Exchnage server at home on a dedicated server.. you will not be able to set your phone up with exchange.
One Suggestion I may have would be to setup outlook on your phone to connect to your email via Imap4 or POP3.
You might want to remove the activesync partnership to your old company if you havent done so allready to help get rid of the exchnage sync error's.
Hope this helps.
Jan 09, 2009 | Microsoft Office Outlook 2007: Windows
Outgoing text vibration
Good Day,
Beginning with the start menu, go to settings, then sounds & notifications. From the drop down list, go to outgoing message and click the "play sound" box (to empty). That should stop the ringing and vibration.
Hope this helps
Jan 02, 2009 | Verizon Communications HTC XV6800 Cell...
Fix Error 80070002
It only takes a few short steps to fix error 80070002
- Search for ppcrlconfig.dll (it should be in C:\Documents and Settings\All Users\Application Data\Microsoft\IdentityCRL\ppcrlconfig.dll), delete it.
- Remove all Windows Live Messenger and MSN Messenger installed.
- Reinstall Windows Live Messenger.
- Restart Windows Live Messenger.
Nov 10, 2008 | Microsoft Windows Live Messanger
ActiveSync from my phone
Thinks jbrickman For ask Me !
Here is Another Problemes about This Phone
icon_ea.gif Error occurred accessing attachments. Verify attachment settings - Inbox Tools/Options/Storage. You should also verify that you have sufficient free storage space. icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2333 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2423 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 817 icon_error.gif icon_ea.gif Error occurred while getting email field. icon_error.gif icon_ea.gif Subject of bad email: 080303 WebEx_Overview_.ppt icon_error.gif icon_ea.gif Bad email received: 3/5/08 6:00:27 PM icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 679 icon_error.gif icon_ea.gif Error occurred while getting Inbox records, records Processed = 45 icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 2957 icon_error.gif icon_ea.gif Error occurred while getting captured Inbox changes, changes Processed = 0 icon_error.gif icon_ea.gif COM Error 80070002.
And The SOlution Here IS :
The way to sync with Exchange Server (as detailed in the documentation that came with the phone and as I have it set up following those instructions) is:
- You go to the verizon wireless website, create your verizon account, enter all the details for your exchange server (address, username, password, etc).
- The VZW server pulls info from your exchange server and then the VZW server sends this info to your handheld.
You may want to call VZW tech support if you are having difficulty setting it up.
And Thanks
Aug 28, 2008 | Apple iPhone 3G
Error message #80070002 treo 750
Ok, email can be setup using a bunch of different protocols. The difference is how directly you phones data and the data on the server interact. POP and IMAP are methods for receiving email from the server, to send they use a protocol called SMTP. With POP3, email is all downloaded to your phone and saved there, with IMAP you only download the headers (...a header is like the back cover of a book). An Exchange server can do SMTP with either POP or IMAP, but when it says configure for Exchange - it means actually connecting to the mail server and integrating contacts, calendar items, email, like the Outlook client on your Windows machine. This is obviously much more server intensive and requires special permissions to do.
POP and IMAP will require the following information to work. Your login name, your password, your server, and whether the connection is secure. To find these out you can go to your coporate webmail. The user name is what you put in the user login spot, as is the password, the server will usually be either mail followed by a dot and the second half of your email address, or the web URL for the mail server...if the web access page address starts "https" then the connection is most likely secure.
This link may help further...
Jul 22, 2008 | Palm Treo 750 Smartphone
Old version of ROM
Looks to me like it's the verizon 6800. Go to www.htc.com/us and follow to the 6800 and download the software by phone and carrier. There is no software for any of the phones on the standard HTC site and the 6800 is not listed on it.
Jun 05, 2008 | HTC PPC-6800 Smartphone
Lands Phones Logo
183 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
