Question about Tappan Microwave Ovens
Aunt bought a "display model" Tappan Over the Range Microwave Oven from Lowes. Did NOT come with the metal "MOUNTING PLATE". Where can I get a MOUNTING PLATE?
I bought a display model from lowes tappan over the range microwave oven, and do not have the mounting plate, How can I get one?
Posted on Oct 07, 2008
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
The instruction manual was not in the box when we bought our new under cabinet mount Maytag microwave (model MMV1163DW00) We just have a basic mounting question. What is the best way to mount our...
run a search for maytag microwave model mmv1163dwoo, then scroll down to installation guide/manual, it was at www.managemylife.com, page 7 in the manual, I believe.
Mar 03, 2011 | Maytag Appliances Over-the-Range Microwave...
Thermador Microwave Oven Model MBBS Serial No FD 8402000337 Runs but no longer heats food. Deep growling sound Light flashes from behind 4.25 x 5.5 " metal plate on right vertical side of oven...
Oh dear, I hope the magnetron still works. That plate you describe is called the Waveguide Cover. This cover must be kept clean otherwise the food particles will carbonize and cause exactly what you have described.
Contact the manufacturers web site for a supplier in your area or look on ebay, espares.co.uk depending on your location.
When it has been changed, I hope the magnetron/aerial is OK.
Dec 29, 2010 | Thermador MBBS Microwave Oven
I'm removing a Maytag microwave over stove model #mmv4205aab. Would appreciate guidance. The only attachments I can see are two bolts which connect the unit to the cabinet above. I cannot see what...
Typically there is a metal mounting plate screwed to the wall and when you take the screws out of the cabinet above it it will tilt forward toward you and then you have to lift it off of some metal tabs that are on the bottom of that mounting plate. Lift up and pull away from the wall and let the cord pull out of the hole in the bottom of the cabinet. Good luck. I usually do that by myself and hook one arm under it and lift it up, but probably better with two people.
Oct 09, 2017 | Maytag MMV4205 Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
My tappan microwave come on but does not heat up food
hi,
              When your oven doesnt heat up please do the following,
  1. Check timer and clock settings
  2. Reseat the element
  3. Test the element
  4. Test the element connectors
  5. Test the oven temperature control
  6. Test the oven selector control
For more details refer to http://www.acmehowto.com/howto/appliance/range/erange.php
May 07, 2009 | Tappan TMS062E1 Microwave Oven
Filter replacement
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
supply.
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Feb 16, 2009 | Tappan TMT104E1 Microwave Oven
Need a glass tray for sylvania
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY THIS IS THE ONLY PLACE I COULD FIND THE PART YOU ASKED FOR ,JUST COPY & PASTE THIS INTO YOUR BROWSER & YOUR THERE.YOUR MODEL # DOES'NT SEEM TO BE COMPLETE,THERE ARE LIKE 2 OR 3 DIFFERANT PREFIXES FOR YOUR MODEL.SURF THE SITE,ITS PRETTY SIMPLE.ITS A LITTLE PRICY,(62$)BUT I DID MY BEST,HOPE THIS HELPS!!!
Nov 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
161 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
