Question about HP Officejet 4215v All-in-One Printer
Cannot send faxes
Originals will not scan for faxing.
  • HP Master
  • 1,879 Answers
FIRST make sure you can do a standalone copy to make sure that the scanner is working.
As FAX is originally designed for use with POTS, check the wall jack for dial tone, plug in a telephone set.
Connect the phone cables properly from the wall to the all-in-one's Line In port.
Then check the fax settings on the unit.
what's your fax number ? i'll send a fax transmission.
Posted on Sep 25, 2008
    Guru:
  • 558 Answers
Thanks for posting in FixYa.
Since you had said that original are unable to fax. Is it means that the fax machine is operating?
If then please check the size controller may be it is jammed between the roller of the fax machine.
Open the cover if it is hang in midway.
Also please check your phone line pulse and its connection to fax? Is it direct or indirect.
Have a Nice day. Dont forget to vote me.
Regards
Ellin
    Genius:
  • 1,011 Answers
Dear,
what happened last time since it is not doing this job
regards,
dont rate it until it cures your problem
  • 81 Answers
Are you using a phone line or PC to fax? If a pc, what operating system?
Posted on Sep 03, 2008
    Master:
  • 763 Answers
Does your fax machine can receive incoming fax? may i know your fax exact model.
    Scholar:
  • 125 Answers
Are you using Windows Vista?
    Master:
  • 521 Answers
Check whether you have loaded the scanner software .
  • 2 more comments
  • tech expert12 Sep 03, 2008
    Make sure the line coming from the wall is plugged into the "L" (line) port on the machine. The port with the icon of a telephone next to it is for an extension phone, answering machine, computer modem, etc. If the wall cord is plugged into the second port, the machine thinks another phone (extension) is using the line.
    Press setup on the All-in-One. Navigate to Advanced Fax set up using arrow keys. Select Answer Ring Pattern and set it to All rings.
    Try to send the fax at a different time when telephone line conditions have improved.
    also readjust the fax settings by pressing the menu button.and setting the fax mode again as required.
4 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Posted on Nov 01, 2007
  • 6 Answers
SOURCE: hp 4315 not scanning
I have the 4315 and have been scanning with it for years; however, when it hangs up on starting the scan,it is usually due to the quality of paper. For example, if the edge that is inserted is not straight and crisp, it may hang up. Try taking a brand new sheet of paper with test writing on it and see if it goes through. Does it make the sound like it is trying to scan and just can't "catch" the paper? Also do you get an error message?
Posted on Jul 18, 2009
  • 223 Answers
SOURCE: Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Posted on Jul 15, 2010
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
When I send a fax there is a wide black strip on the recieved copy. What is causing this and how can I fix it? I have already tried replacing the drum and that didn't work.
open the top potrion (the op panel) and see if there is something on the scan glass, it should be a thin strp of glasis as wide as the paper. If not, the light that scans the originals my be bad.
Oct 06, 2010 | Brother IntelliFAX 4100 Laser Fax
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
dialed.
3. Press START FAX Black.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
When you send a fax, the other person only gets lines on there copy, not the paper that i faxed
Make a copy with your fax machine. If your scanner is bad you should have a similar problem making copies. The same scanner is used to make a copy as is used to scan and send a fax. If the copy comes out bad your scanner is either dirty or bad. If you can see your copy but it just has a few lines running vertically up and down the page then you need to clean the scanner glass. This is a small strip of glass in the port where you feed it your originals.
Good Luck
Jan 25, 2010 | Panasonic KX-FP151 Plain Paper Thermal...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Sent documents are received black
I bet if you make a copy for yourself, the same thing is true.
The scanner bulb (or led array) is dead - meaning there is no light coming on when you scan your originals to send a fax or copy. You would normally be able to see the light(s) light up, if you peek under the auto sheet feeder as your originals are scanning, if not, then it is dead.
Jul 16, 2009 | Sharp UX 340LM Plain Paper Thermal...
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
When I fax the recieptent is getting 2 big black lines..........ive tried cleaniung it but not sure if im cleaning the corredt parts..........there a little glass part that looks like there may be ink
Open the auto sheet feeder (where you place your originals), look underneath and you will see a narrow "scanner" glass that the originals are scanned across. Clean this thoroughly with glass cleaner (or water) - there is probably correction fluid or some other foreign dirt on it. If you make a copy for yourself (before and after) it gives a good indication of the quality you are sending to fax recipients.
good luck, and please rate solution
Apr 28, 2009 | Brother FAX-575 Plain Paper Thermal
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
HP Officejet 4215v All-in-One Printer Logo
80 people viewed this question
Ben Johnson
