Question about Hotpoint Dryers
Advice on whats wrong with my dryer
My dryer was working ok the last time i used it but now its not blowing hot even though the led light indicates its drying
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Check that the lint filter is cleaned before every load and that the vent that is outside is not clogged up with lint. There is a flap door on a sprig action that must open when the dryer goes on.
Or a screen that keeps small animals out that if cogged even half way , you will not get heat!!!!!
Other than these recommendations there is a good service company I listed down below!
If the appliance is 10 years or older its not worth investing money to ix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Indicator fuses keep blowing even though i have changed them about 30 times in the past week. indication lasts about one indicate and then blows. dont want to waste money taking it to get looked at by a...
hi means u have a short in the system check all the indicator lights some times it can be caused by a badly blown bulb or corrosion in the bulb socket make sure no wires pinched together also pay to check flasher unit if all ok it may be your indircator switch good luck
Sep 11, 2011 | Toyota Corolla Cars & Trucks
Dryer model # GE DHDSR46GGWW igniter glows but no flame or indication of gas. At first when I hit the solonoid it ignited, but not anymore. I checked the connections, all seem ok. I figure the solonoid is...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[][
Sep 01, 2011 | General Electric DHDSR46GGWW Gas Dryer
I have a Kenmore 600 gas dryer and every once in a while it does blow hot air. It tumbles and seems OK other than that.
heatman101 ' '; ';
Aug 12, 2011 | Dryers
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
The drum is turning but it's blowing cold air, no hot air not even warm. The last time it was used it was hotter than usual, but now nothing.
heatman101;
Aug 04, 2011 | Dryers
My dryer heats up ok but after a short time it just blows cold air
heatman101][
Aug 03, 2011 | Dryers
My dryer working not blowing hot air? what do I do?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 04, 2011 | Dryers
Dryer has power, dim control leds, will not run most of the time.
Same problem here. I replaced the machine control electronics p/n 8546219 and got 12 months service out of it before it returned to what you are describing above. I even replaced all the LED's on the board and that did not do a thing. I can tell you that this will be the last whirlpool appliance that will ever enter my home. Simply overpriced garbage!
Jun 06, 2009 | Whirlpool GEW9250 Electric Dryer
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Power supply problem with led light blinkng 12 times. had tele 1.5 yrs and sudenly stopped working. checked fuse next to relay switch, keeps blowing. any advice?
The blink code will indicate the problem circuit. I need the make and model to decode that though. Please update this with the make and model.
Thanks,
Dan
May 23, 2008 | Televison & Video
Dryers Logo
65 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
