Question about Dryers
I want to install a dryer but cannot vent to the outside of the condo building. Can I use the bathroom ceiling vent or is there another solution? I am on the first floor of a 2 story building.
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
You can buy a vent less dryer filter at the hardware store or Lowes, or Homedepot!
Some vent into a bucket of water and wooola!!!!!!No dust!
I used it once in an apartment like you need!
If the appliance is 10 years or older its not worth investing money to ix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Wet ceiling from my bath exhaust fan, how to stop?
Probably due to 1 0f 2 things...
1- Not enough power in the exhaust fan to take out all the mist /steam from the shower.. or
2- Condensation build up due to too much steam at one time.
(especially if fan is NOT ventilated properly)
If you have access to the fan, see if the label states the CFM 's it can remove. May not be enough for the size bathroom you have.
Both of these can be solved by installing a larger capacity fan system. Make sure to vent it to the outside of the home too, since venting to a cold attic area (in winter) can cause even more condensation to drip down.
Feb 17, 2017 | Home
THERE IS A MAIN AIR VENT IN THE CENTER CEILING THAT BLOWS COOL AIR. SHOULD THE SMALL VENTS IN OTHER ROOMS WORK TOO? & WHY NOT?
Hi Missy:
Your question is in the cars and trucks section, but it sounds like it is about your home ventilation system.
I'm thinking that you probably have an HRV (Heat Recovery Ventilation) system that you are asking about.
- Even in the non heating seasons, these units are intended to operate for 20 minutes of every hour, when humidity gets high, or when a manual timed switch is pressed for bathroom exhaust fans.
- Inside air from the bathrooms and possibly kitchen is sent through the HRV to the outdoors.
- Fresh outside air is drawn in through the HRV at the same time and distributed throughout the home via the vents you are referring to.
- These devices are designed to improve air quality in the home, AND to reduce costs in the heating season.
- Additional devices like furnaces, air conditioners and heat pumpscan be part of the system so it can get complicated.
-If possible, I would be trying to check with the builder of your home to find out what system had been installed.
Hope this helps.
Ted (Retired Building Inspector)
Jul 06, 2015 | Cars & Trucks
How to vent exhaust outside
bea12bfe-3a65-4764-8544-5bc63391c2dc.jpg9dbdeaa6-0b81-4926-ab21-2206dc8f6420.jpg6bfcce66-f35e-4950-b5c4-5ba9eff2c34c.jpgI usually choose an outside wall if possible to vent outside. You can buy a rear vent that is superior to a dryer vent. When this isn't possible you need a rectangular duct going up through your cabinet and up through your ceiling. hopefully you have an attic or you have to switch to a 5 inch tube going sideways (above your cabinets (if there is space) to the outside wall. If it goes into an attic you have to cut through the shingles to a vent made for bathroom and or hood vents. The motor and blower assembly inside your microwave is designed to turn to be front facing, rear facing or vertical facing. Just unscrew or break out the side that you need to vent through.
Oct 21, 2013 | GE Spacemaker JVM1540 Microwave Oven
I recently purchased a Danby Premiere 13000 btu portable air conditioner. I live in a condo with swing out windows. What are my options for venting (short of returning the unit for a refund or replacing...
John, unfortunately, you don't have many options, short of putting a hole in an exterior wall and putting an exhaust pipe with a cap (like a dryer vent has) and connecting the exhaust hose to it. OR if you have a clothes dryer in your condo and it's vented to the outside. You could temporarily disconnect the dryer's vent hose and connect the A/C's vent hose to the the dryer's outside vent.
Either way, it may be to much of a hassle . But, I'll let you decide that. I guess it will all depend on how hot your condo gets without A/C.
Let me know how it works out for you. Thanks.
May 05, 2011 | Danby Heating & Cooling
We own a "converted" condo unit in a building that was previously apartments and now each unit is sold as a condominium unit. I have read about others having issues with cigarette smoke coming in through...
Hello,You need makeup "fresh" air intake vent added.You have a attic fan or when a clothes dryer,range hood,bathroom fan runs it pulls the house into a vacuum or negative pressure.It will pull air from anywhere it can to balance the pressure.Try leaving a window open a little bit for a couple of days(if you can do safely)and see if it works.Then you need a outside air vent installed.I assume the AC intake/return are seprate from the neighbors.
Oct 10, 2010 | Honeywell Electronic Programmable...
My Kenmore dryer (model # 417. 93142201) has intermittent heating
There are times that the electrical code is not followed and dryers are wired into two 15 amp breakers rather than one 30 amp breaker. If two 15 amp breakers are used, they can be tied together. All that leads to a possible solution, check to see if you have two 15 amp and if both of them are turned on.
Jan 25, 2010 | Dryers
Takes the dryer over two hours to dry one load of laundry. It appears to be putting out hot air. When I stop it to check the clothes, the clothes are usually really warm yet still wet. This has been going...
You have a venting problem. Some makes of condo size dryers have a lint screen inside the drum at the back. Check and clean. If not then there might be a screen in the wall or the ceiling of the room the dryer is in. Trace the vent from the dryer to the wall or ceiling. There should be a vent fan in the ceiling. Try asking the condo property management if there is an exhaust fan in the wall that needs cleaning.
Jun 21, 2009 | Dryers
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
Drawing combustion air for a gas dryer
I am assuming that this is a gas dryer not an electric dryer.
Per the 2009 Uniform Mechanical Code Section 902.0
(B) Gas utilization appliances shall not be installed so its combustion, ventilation, and dilution air are obtained only from a bedroom or bathroom unless the bedroom or bathroom has the required volume in accordance with Section 701.2. [NFPA 54:10.1.2]
Section 701.2 basically says you need to provide adequate combustion air. One way is if the volume of the space is 50 cubic feet per 1000 btu. I personally think it is a bad idea to obtain combustion air from a bedroom even if it has adequate volume; it used to be prohibited by the Uniform Mechanical Code. The combustion air requirements are based on the BTUs of the appliance not the CFM. For gas pipe sizing purposes the Uniform Plumbing Code says that clothes dryers have a BTU input rating of approx. 35,000 BTUs. One 4" duct to the attic with the opening of the duct inside the closet within 12 inches of the ceiling would provide enough combustion air per the "One Permanent Opening Method" in UMC chapter 7.
Make up air is a different requirement than combustion air. Chapter 5 of the UMC states that if you have a dryer in a closet you need to provide a make-up air opening of 100 sq inches. The make -up air is to replace the air that is being exhausted not to provide air for combustion. The make -up air could be taken form the exterior of the building or another room within the building. Technically the closet should be insulated and weatherstripped if you get the make-up air and combustion air form the exterior.
Sorry doc john but the fire inspector is not talking about the exhaust duct (environmental air duct). That is required no matter where you have installed the dryer and is a totally separate
Oct 07, 2008 | Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
