Question about Dryers
Maytag Dryer The timer on my electric dryer does not move when drying and therefore does not shut off after the alloted time. It will continue to run indefinitely. If you set it to time/dry for 20 minutes it will still be running 2 hours later and the timer will be on 20 minutes.The problem is NOT the timer, I put a new one in it and it did the same thing. I thought I got a bad new one so I got another new timer (at $77.00 each) and it still does not work. Nothing is binding around the knob or timer mechanism. I'm stumped Please help! Maytag model # MDE7657BYQ
  • 1,031 Answers
Did you replace it properly? The purpose of a dryer timer is to control the unit's cycles by regulating the length of time that power is directed to each component. It is not common for dryer timers to malfunction, and they are often misdiagnosed as having failed when they are actually fully operational.
TIP: If you do have a timer motor that has failed, consider replacing just the motor itself and not the entire assembly. Timer motors can be considerably cheaper than the complete timer assembly.
Before you can replace your dryer's timer assembly, you must first locate the device. Timer assemblies are located behind the control console panel. You may only have to remove the screws securing the front control panel in place, or, depending on your model, you may have to remove the rear panel behind the control panel.
Remove the timer knob from the timer's shaft. Now remove the timer's mounting screws. Discard defective timer and replace with a new one. Secure the new timer in place of the old one. Reassemble your dryer's control panel and restore power to the unit.
Posted on Aug 28, 2008
  • Starnley Johnwells
    Starnley Johnwells Aug 28, 2008
    Before you can begin to test your dryer's timer motor, you must first locate the device. It is a part of the timer assembly. Dryer timer assemblies are located behind the control console panel. You may only have to remove the screws securing the front control panel in place, or, depending on your model, your may have to remove the rear panel behind the control panel.
    Label the wires connecting to your timer motor so that you will be able to correctly reconnect them later. Carefuly remove the wires. Do not pull on the wire itself. Instead, use needle nose pliers to pull gently on the wire connector.
    Set your ohmmeter to the R x 1 setting. Take each probe and touch it to one wire. A normal reading for most dryers is in the 2000 to 3000 ohms range. Try to locate a schematic for your dryer. It should be in one of the service areas of your dryer or in the owner's manual. This schematic should indicate the proper resistance reading for your specific timer motor.
    If the reading you receive from testing your timer's motor differs greatly from the range presented here, then you should replace your timer motor, or the entire timer assembly.
  • 435 Answers
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
    Genius:
  • 3,422 Answers
HI,
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Timer buzzes then shuts off dryer
you need to replace the timer if it is stopping the dryer before the end of the cycle.
Sep 30, 2009 | Maytag MED5600TQ Electric Dryer
Dryer takes a long time to dry clothes
your timer is the problem if its not moving
which can be expensive
60-80.00 dollars Dryers are cheap enough to buy a good used one
Jun 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
MAYTAG SDE3606AZW ELECTRIC DRYER
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Maytag DE 412
Does sound like the timer, although the clock is moving, the contact for the heater element is burned out inside the timer, you probably have used this timed dry for your normal day to day use and worn out the contact, new timer required.
May 25, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
471 people viewed this question
Top Dryers Experts
