Question about Ricoh Office Equipment & Supplies
Alert Message: Replace PCU: color - Ricoh Office Equipment & Supplies
  • Anonymous Nov 21, 2008
    Ricoh Aficio SP C410DN
    Replace PCU: Black soon - Contact your local vendor
  • Anonymous May 12, 2009
    Ricoh Aficio SP C820DN
    Problem Solver:
  • 3 Answers
What is the make and model of printer?
Posted on Aug 28, 2008
How do fix error Color registration could not performed
Possible remedies for weak images.
-Loose connection between transfer roller and high voltage supply unit.
-Dust in the laser beam path
-Transfer belt not contacting PCU.
Check the transfer unit.
Defective PCU. Replace the PCU.
Defective transfer roller. Repair the transfer roller.
Defective fusing unit. Replace the fusing unit.
Defective engine board. Replace the engine board.
Feb 02, 2016 | Ricoh Aficio SP C410DN Laser Printer
How to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
My printer flashes alert CS 441 off on. Can you tell me what's wrong?
The SC 441 is a color pcu motor lock. One of the waste toner augers is clogged with waste toner not letting the drum turn. The only real fix is to replace the color pcu unit. If you could get the auger and drum out it might be possible to free it up, but you will probably damage the drum in the process.
Apr 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Light blue lines in the color pages
Yes :
You should replace the PCU if prints show any of the following symptoms.
  • Colors are missing, faint, or partially blurred.
  • Toner smears appear.
  • White or color rivers appear.
  • White or colored streaks appear.
    1. Important: Switch off the device and disconnect it at the mains.
    2. Open the right side cover.
    3. Pull the green levers as shown to release the inner cover.
    4. Lift the inner cover upwards.
    5. Squeeze the green lever on the black PCU.
    6. Pull the unit carefully out of the device and dispose of it in accordance with your local environmental policy.
    7. Place the new PCU on a flat surface.
    8. Peel off the tape from around the new PCU.
    9. Remove the top cover from the PCU. DO NOT remove the bottom cover at this stage.
    10. Rest the new PCU in the device as shown.
    1. Push the PCU into the device while holding the bottom cover. You will hear a click when the PCU has locked into place.
    2. Lower the inner cover.
    3. Push the two green levers as shown to secure the cover.
    4. Close the side cover.
    5. Connect the device at the mains, switch it on and wait for the self-test operation to finish.
    6. Please remember to rate all users who assist you for free :)
Sep 07, 2008 | Ricoh Aficio CL3500N Laser Printer
Aficio CL3500N Photo Conductor Unit
If your print outs are clear and the PCU is surely new.
Press Menu
Scroll to Maintenance <Press Enter>
Scroll to Replacmnt Alert <Press Enter>\
Scroll to PCU <Press Enter>
Select Notify Later <Press Enter>
Good luck.
May 20, 2008 | Office Equipment & Supplies
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
1,434 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
