Question about HP Photosmart C5180 All-In-One InkJet Printer
Carriage jam There was a paper jam.  I opened the back and pulled out the paper,but it tore.  I got all the paper out that I could see, closed all the doors, turned the printer off for awhile and then turned it back on.  The error message"carriage jam" will not clear and I cannot use the printer.  I have looked in the printer to see if a small piece of paper in still there, but I can see no more paper.  How do I clear the message and use the printer?
    Master:
    Sergeant:
  • 398 Answers
I don't have the same model, but I do have three hp photosmart machines here, and I usually reach in and grab the carriage and give it a little pull and push, once it has moved it will then go to its place. A word of caution, turn off the printer before you try this. Then turn printer back on after closing lid. I think I learned this from one of the manuals or their web site.
Posted on Aug 28, 2008
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Tip
Steps to clear paper jam.
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
How do I re-set after a paper jam hp psc 1200?
Verify that the print cartridge door is closed.
The print carriage may be jammed, follow these steps to correct the problem:
1.
Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
2.
Disconnect the power cord from the all-in-one.
3.
Remove both print cartridges.
4.
Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
5.
Close the print cartridge access door.
6.
Plug the power cord back in.
7.
After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
8.
Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
If that doesn't work, maybe try this too:
Clearing paper jams
Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
1.
Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
2.
Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you.
NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
If under warranty, contact HP to obtain a replacement part.
Click How to buy on this page to order replacement parts.
3.
From the rear access door opening, gently pull the jammed paper free.
4.
Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
5.
Reattach the rear access door by inserting the two pins on the right of the door into the holes for them and then pressing in gently but firmly on the left side.
6.
Reconnect the power cord to the unit and turn the unit on. Source(s): http://www.castleink.com
Sep 01, 2010 | Computers & Internet
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Mar 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer
2.
3.
4.
5.
6.
7.
Jun 03, 2008 | Office Equipment & Supplies
Paper jam?
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
139 people viewed this question
Ben Johnson
