Question about IBM ThinkPad T20 2647 Notebook
Black screen everything seems to start I can here the fan the cd lights up and spins but the screen is black also the only light that is on is the circle withe z in it... thanks fo the help...
  • 1 more comment
  • waltdawgg77 Aug 28, 2008
    1 where is the power management component located...
    2 what does the light circle with the z in it mean...
    how can I get it out of sleep mode? thanks for all your help your the best...
  • Rakesh 007 Nov 14, 2008
    I have a ibm laptop but it is comes with dim light. i am all redy change TFT FL ( high voltage invertor ) but it is same.can you help me. and ca you give me laptop circuit goid book.
    Genius:
  • 2,028 Answers
This is going to be one of three things, 1- bad battery, remove the battery and try starting on the adapter only. 2- bad memory chip or memory slot, remove the memory and try each chip one at a time in each slot, and 3- a failed power management component on the motherboard. If 1 & 2 don't work, then the problem will be with the power management system, which is a common problem with these machines. Unfortunately, motherboard replacement is the only option with a failed power management system.
Posted on Aug 28, 2008
  • Ryan Rogers
    Ryan Rogers Aug 28, 2008
    The power management system is a series of components integrated into the motherboard that controls and regulates the power input, charging, switching from battery to AC, and other functions, not just a single component, although it could be a single component of this system that is causing the problem. In order to track down the exact problem component you need specialized diagnostic equipment and a fairly extensive knowledge of motherboard components or a trace diagram of the board in question. The circle Z is for the sleep mode.
Dell inspiron 560 problems
chek your video card it my be going out
Apr 30, 2013 | Dell Inspiron 560 PC Desktop
My acer desktop computer screen is black, the power says it is on but no pic, keeps cutting off, tried to back up and restore, cut off, says problem with windows and it shut off as well, HELP!
  • When the computer will not boot up, it sound like it is booting as the CPU fan is running and the lights are on. It also finds the CD ROM but it won't boot from a CD either.
  • Sometimes when you have a computer black screen on startup and the power switch light will be green and then turns to orange or amber. Everything is running.
  • Everything seems to be running but you can't see anything on the screen, not even a flashing cursor. Your black screen in Windows has occurred before the Windows logo screen:
  • 1- adapter or video card
  • 2-RAM
  • 3-and Black screen on startup with an amber flashing light
  • Not enough power getting to the motherboard.
  • A dead power supply.
  • A bent pin or shorted out USB port causing a problem.
Apr 09, 2013 | Acer AX1430-UD30P Desktop Computer With...
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
My nec p9120 has power to it and the wi-fi is on but the fan and everything else is not running and my lcd screen stays black
Try connecting to an external monitor and see if that works. Is the hard drive activity light flashing at all?
Mar 20, 2012 | NEC Computers & Internet
Wifes Acer laptop screen went black, power light is on, fan is running, but nothing comes up on the screen.... We're stumped...
If you reboot it and everything seems normal except there is no display, get a flashlight and examine the screen for a display with no backlight. Maybe it is just the back light power supply that has failed?
Hope that helps.
Jan 15, 2011 | Acer Computers & Internet
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Avertec 2300 laptop will not start. Have tried removing ram and battery. All I get is a blue power light and wifi light. HD clicks a couple times and cd drive spins if there is a cd in it. Fan does not...
Hi as for symptoms you have problems with you hardware. Basically thats means that one of the devices like harddrive or Video card fail to go through POST test. You can check your users manual for this very symptom
Sep 15, 2009 | Averatec Computers & Internet
Toshiba A75 Wont Boot up
It sounds like you may not have made a good connection to the motherboard from the screen when you put everything back together.
When you press the power button does the screen come on and then go off or does it not come on at all ?
If it comes on then turns off try to eject the CD-Rom that will be a definitive test of whether your power is still on, assuming your cd-rom is not totally mechanical.
Jan 29, 2009 | Toshiba Satellite A75-S226 Notebook
Screen is black
When you say sounds like it starting up, can you hear the Windows sound byte, or just the hard drive spinning and CD drive engaging?
Aug 12, 2008 | Dell Inspiron E1505 Notebook
IBM ThinkPad T20 2647 Notebook Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
