Question about Pentax *ist D Digital Camera
*ist-D date/time setting problem
Somehow, my *istD does not remain its date/time setting. If I change the main batteries(CR-V3 or NiHM), the date/time display comes up and shows "01/01/03 00:00" The camera remembers every settings except date/time. I've replaced the back up button battery and upgreaded the firmware but didn't work. Actually, it is my 2nd *ist-D. first one had a bad CCD and storing date/time problem. so I returned it and received the replacement but this one has also storing date/time setting problem. (I'm very curious that how come two of the *istD have the same problem.) Does anyone has this problem? Any suggestion?
    Master:
  • 542 Answers
This is a very old thread but it is on topic - i am having the same troubles with my ist d. the camera (apparently randomly) resets its date/time on occasion. i checked the back up battery voltage and its fine. has anyone else had this problem and if so how did you fix it?
Posted on Sep 08, 2005
    Master:
  • 542 Answers
I had exactly that problem with my first *ist D. Replace the AA batteries and the time was always lost. A new 'button' battery didn't fix the problem. The camera was replaced. The second camera had to be returned too. While I was with the dealer he told me my first camera wasn't really faulty as Pentax UK had been able to tell him how to fix it by some routine. I must admit I didn't listen hard to what he said, I was more interested in getting my hands on the third camera - and then the fourth when that didn't work either.
The indicator shows low battery after 2-3 shots. (batteries 3800 MAh are fully charged)
This seems to be a problem with the ist line. My istD does the same thing. Turning it on and off a few times helps with mine. Pentax has no solution.
Sep 24, 2010 | Pentax *ist DL Digital Camera
Broken door to battery compartment
Here's a possible source, though I'd check to see whether the battery covers for the ist and the *ist are the same.
http://uscamera.com/istd.htm
Jul 05, 2010 | Pentax *ist DL Digital Camera
Battery indicator reads empty when batteries are fully charged
It looks like your question was cut short... all I see is "Battery indicator reads empty when batteries are..."
With my experience with the Pentax *ist DL, I think the problem is probably that brand new batteries still show "empty" on the indicator.
Chances are that you are not using the CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
Neither lasted anywhere near as long as the CR-V3 batteries! While you may be paying $15-$20 for two CR-V3 batteries, they last a LONG time!
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500+) instead of $10-$15 ($2-$7 for film + $8 dev/print) for every 24-36 photos!
May 29, 2010 | Pentax *ist DL Digital Camera
My camera indicates that the batteries are low and won't power on. But, when I put new batteries in, it still indicates low battery. What can I do?
Chances are that you are not using CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500 ) instead of $10-$15 ($2-$7 for film $8 dev/print) for every 24-36 photos!
May 09, 2010 | Pentax *ist DL Digital Camera
Power / batteries
This is a common problem...sometimes you have to turn it on a couple of times.
Mar 17, 2010 | Pentax *ist DL Digital Camera
Main Battery Power
It cannot switched the batteries. The backup one is a small internal battery just to keep the CMOS with data. That's it.
If you main battery is not charging or when unplugged won't power on, the is likely the main battery is defective, or the charging circuitry of it is failing.
Best regards,
Jul 01, 2008 | HP iPAQ RX3115 Pocket PC
Date/time problem on *ist d
There is a small re-chargeble battery inside the camera that charges of the main battery. Chances are that battery had just drained when the date/time reset occured, but should be fine after you recharge.
Sep 08, 2005 | Pentax *ist D Digital Camera
*istD battery problem
Battery charge indicators don't measure actual charge but voltage because there is no cost-efficient method to measure battey charge directly. Instead, batteries are designed so that voltage goes down with charge. Now, the difficult thing is that not all batteries behave in the same manner. It is actually very hard to predict how a battery menufactured by xyz behaves. I would guess that Pentax engineers did not have Energizer AA's in their mind when they defined the voltage alert level. I would suspect that the battery status indicator is calibrated for the CR-V3 batteries that were included with the camera body, or something else. Only wild guesses above... And yes, I have encountered weird inidicator behavior with AA batteries, too. But not with CR-V3. I bet your mobile phone battery indicator plays tricks, too.
IstD LCD Screen...Problem
Resolution on the LCD is rather "rough," but I think all these tiny screens are that way. Considering the "roughness" of the photos in playback, and their sharpness when viewed full on on a computer, the text is about up to as good as this screen can produce. Or, in other words, I'm see'in what your see'in as for text. I think it's just normal.
*istD Problem with Vertical Grip
Digital cameras require a large 'surge' of power when performing things like processing an image and saving it to the memory card. Alkaline batteries work best when used in a device that draws power at a steady rate. They do not work as well when asked to provide a surge of power. Your batteries are indeed not dead, but they are sufficiently depleted that they can no longer provide that surge that the camera requires. Take them out and put them in something like a TV remote or a radio. They probably have quite a bit of life left. NiHM and Lithium based batteries are much better at being able to provide the amount of current needed right up until they go dead. The 100 shots you got out of your Alkalines is at the high end of what you can typically with Alkalines in your camera. The continuous shooting could be a symptom of the batteries getting low. Another option to those previously listed are AA Lithium batteries which are cheaper than CR-V3's and last nearly as long. They are not rechargeable though.
Pentax *ist D Digital Camera Logo
133 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
