Question about Pioneer Audio Players & Recorders
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. Nothing happens after that and the system doesn't work. Could you help me to fix this problem? Thanks
    Problem Solver:
  • 19 Answers
On the first board (where the power enters) there is a tall 3 pronged switch, if you turn the board over and solder a piece of wire to the 2 outside prongs, you will find that the Amp works normally apart from that the display reads Cd closed when in Cd mode.
Posted on Jun 22, 2009
You could try opening up the machine, and shorting the service pins. This will clear the unit of any internal error codes. I hear that this can be a complete solution for some units - they never hiccup again. But don't get your hopes up if this does work - mine worked for about a day, then broke again.
I could refer you to this: http://sci.tech-archive.net/Archive/sci.electronics.repair/2007-05/msg00065.html
Posted on Oct 28, 2008
  • icedtrashcan Oct 28, 2008
    Oh, forgot to add - there is a capacitor which is known to fail within the metal shield of the board that connects to the display wire (back right, if the back of the unit is facing towards you). You could try replacing this with a new 47uf capacitor - that'll cost about 20p if you do it yourself, or find a friend that's competent with a soldering iron.
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I own an Pioneer CD
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
The service manual is available for free after you register here...
http://www.hifiengine.com/manuals/pioneer/m-l11.shtml
Posted on Mar 24, 2011
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
My pioneer radio wont stay tuned in
You need a 12 volt battery connection at the stereo.
Aug 11, 2012 | Pioneer Deh-1420ub Car Stereo Cd Mp3 Wma...
Pioneer XC-IS22CD 100w CD/Tape/Radio Stereo what is the size of this
dear sir this is it all
Dimensions (W x H x D) 215 x 372 x 274 mm (S-IS22 speakers)
Dimensions (W x H x D) 160 x 300 x 237 mm (M-IS22 Amplifier)
Dimensions (W x H x D) 204 x 300 x 237 mm (XC-IS22CD head unit)
just tell me if i was helpfull
Aug 12, 2011 | Pioneer IS-22CD CD Shelf System
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. After consistent attempts to put it on, it works but when put off and...
Mar 24, 2011 | Pioneer Audio Players & Recorders
My Emerson stereo MS9903TTC won't turn on. It was working fine last night and this morning when I push the power button nothing happens. I tried selecting different modes, (cd, tape, phono, tuner) but no...
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Feb 10, 2010 | Emerson Audio Players & Recorders
Stereo CD player/tuner XC-L11 not working at all
Just fixed mine - replaced 35v 47uf electrolytic capacitor in awu7837 module (inside shield case) - this module connects to display unit. see www.circuitsonline.net/forum/view/14478 for more info and diagram Cost - 16 pence from Maplin p/n se47m35 kq68y
Regards, Dave
Jun 21, 2008 | Audio Players & Recorders
Teac A-H300 Amplifier
I found the problem....one thread of one of my speaker cables was touching the backboard of the amp and shorting out - problem solved!
Mar 30, 2008 | Teac A-H300 Amplifier
Pioneer Model Is21 stereo
Switch speaker wires if sound switches then amp probably has a final amp ic.output problem. Try balance control and tape dubbing or loudness buttons to see if any are dirty.
May have to get repairs at a shop if the amp is worth saving.
Good Luck
BIG RED
Nov 02, 2007 | Audio Players & Recorders
876 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
