Question about Insignia NS- 27" TV27 TV
INSIGNIA NS-LCD27FS Hi I got problem with my tv when i turn on power red button on front turns in to blue from red but tv is not powering up. can you help me. Thanks
  • 4 more comments
  • ravi118 Sep 02, 2008
    There is any way i can fix power board
    How can i fix power board of Insignia 27 LCd
    on tv and remote
    on tv and remote both
    Hi
    I am a electrian if you can help me little i will able to fix it. Thanks
  • ravi118 Sep 08, 2008
    power board looks ok there is no damage on it capistors are ok
  • 2,071 Answers
The condition of your TV called power supply overcurrent shutdown. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
Posted on Sep 02, 2008
    President:
  • 1,263 Answers
Does this problem occure when using remote or the button on the tv?
  • 1 more comment
  • Ronald Mueller
    Ronald Mueller Sep 02, 2008
    you should not have to replace the whole board, just the supply module. most often times it's a solid state chip that plugs into the board and is not a soldered connecton. you should be able to purchase this and do this yourself bt just removing the back of the unit. this will at least save you the cost of the having a tech do it. how ever if you have little or no expeirence i would not recomend the repair by other than a qualified serviceman.
  • Ronald Mueller
    when you open up the set you should see the connections from tthe chord to a board which has a solidstate chip compnant on it check the soldered connections look for heat marks. with the set unplugged remove this whole section
  • Ronald Mueller
    Ronald Mueller Sep 08, 2008
    if the powersupply module is ok then the main board is fried, it's obvious that you can't seem to get a picture if though you have power to unit and from power supply module to the main board . in that circuit is the fault. unless you have the neccessary schematics and voltage values. any attempt to repair this yourself is ill advised
  • Insignia Master
  • 13,433 Answers
Hey,
Generally such issue tells about a faulty power board or possibly a blown fuse / bad capasitors and to that direction.
Unless you have experience in troubleshooting electronics, useing a soldering iron and so on. I suggest you contact a service center and take the tv in for repairs.
If your tv is still covered by warranty then that will solve your problem.
This definitely requires internal diagnosis.
Thanks,
Ekse
  • Ekse Sep 02, 2008
    Generally you would need to purchase a few tools, a service manual and parts to repair this yourself.
    If the powerboard is at fault, the best solution may be to replace the board, or repair it. If you don't have tv repair experience I recommend agains trying to fix it yourself.
    Guru:
  • 1,894 Answers
You may have damaged the power board.
do you have surge protector or not?
  • dewan nafees ahmed Sep 02, 2008
    yes you can fix it if you have proper expertise in repair and fair knowledge in electronics and electrical.
    mostly there would be a damaged capacitor or burnt diodes.
    you can open the unit and check for the blown out capacitors. they will appear as bulged over their heads.
    if any diodes are burnt you can clearly see them as black burnt area in your board.
    but if the boards print has been burnt there nothing we can do by ourself.
    everything will depend upon the damage caused.
    thank you
    be careful while handling the unit with power ON
The power light on my flat panel tv flashes from red to blue repeatedly and will not turn on
check for faulty capacitors on the power board.
thats where to start.look for ones that are buldging at the top or leaking
Mar 24, 2013 | Televison & Video
How does Insignia TV turn on
THE MAIN BOARD, usually is a 3vdc-3.3vdc signal to turn on the power supply
Feb 01, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Insignia tv light blinking red and blue
you have a faulty parts inside..try to disconnect one by one the supply of all board until you get stable lights..
Jun 14, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Insignia NS LBD32x-10a blue ray/dvd
Try power-cycling your TV (e.g. turn it off and unplug it for several minutes). If the TV then powers on, reset to factory defaults. If the problem persists, your TV will require repairs. Service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
May 14, 2010 | Insignia IS-LCDTV32 32 in. Television
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
May 15, 2009 | Insignia Bluetooth Wireless Headphones...
No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to jah2mil@homtail.com
Apr 17, 2009 | Insignia IS-LCDTV32 32 in. Television
How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
Jan 27, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia NS-32LCD will not turn on.
WIth the set only 7 months old, it should still be under warranty. The problem now is that by opening it up, you effectively have voided the warranty. That being said, the problem is that a problem has been detected internally and the set shuts down to prevent further damage. The first suspect is the main power supply board. I would try for warranty service first. If that is not available a local service shop should be able to take some measurements inside to detemine whether the power supply is not working correctly or if the suply is being told to shutdown. WIth what little info is available here and not being able to examine the actual unit, remote diagnosis will be difficult.
Keep us posted.
Dan
Aug 25, 2008 | Televison & Video
Insignia NS- 27" TV27 TV Logo
342 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
