Question about HP Office Equipment & Supplies
I removed printing cartridge from ptinter[hplaserjetp1006] i am now unable to reinstall it.
    Master:
    Sergeant:
  • 398 Answers
Take a look at the cartridge and you should find an arrow on tip of it, this is the side you insert first, it will go in, and you may have to wiggle it up and down just a little, but and you may have to pull it back out and raise or lower it a little, but they usually find the track and go right on in.
Posted on Aug 28, 2008
Has new cartridges new printhead will not print, only blank white sheet comes out of printer
If your cartridges and print head are new and printer won't print, you have a serious problem and if you don't have the technical knowledge, I fear you can'r repair it yourself, so you should take your ptinter to service
May 04, 2015 | Kodak ESP 5250 All-in-One Printer
I keep getting the print alignment form every time I start the ptinter. I don't want it except when I change cartridges. How can I stop the unwanted printings of this form.???
check your settings. it might be set up to do a print page at start up. check the settings to make sure it is not set uo this way.
Aug 15, 2008 | HP Computers & Internet
Printer Brother DCP-150 cp Unable to print
Remove foreign material in ptinter or change maintenance unit
Dec 22, 2013 | Computers & Internet
Incorrect cartridges message on printer screen c4183. help me
Complete the following steps in the order presented until you resolve the issue. Step one: Remove and inspect the cartridge
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the carriage is idle and silent.
  3. Press down gently on the top of the cartridge to release it.
  1. Figure 2: Removing the tri-color cartridgec00484998.gif
  2. Slide the cartridge out and inspect it.
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear protective tape has been removed from the nozzle and electrical contact area. Figure 4: Removing the clear protective tapec00211538.gif
  3. Reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step two: Make sure the cartridge is compatible Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, click this link, HP SureSupply . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.
  1. If the cartridge is compatible, reinstall it in the printer.
    • Place cartridges marked with a triangle in the left carriage slot.
    • Place cartridges marked with a square or pentagon in the right carriage slot.
    Figure 5: Print cartridges installed correctlyc01091334.jpg Figure 6: Direction to insert the print cartridgesc01091335.jpg
  2. After verifying that your cartridge is compatible, reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step three: Clean the cartridge contacts
  1. Open the printer lid and wait until the carriage stops moving, and then unplug the power cord.
  2. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: If you are removing a tri-color, photo, or gray photo print cartridge, try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
  3. Dip a clean cotton swab in distilled water, and then squeeze it to remove most of the moisture.
  4. Clean the print cartridge contacts. Do not touch the nozzles. Figure 7: Cartridge electrical contactsc00832021.gif
  5. Clean the contacts inside the carriage, inside the printer. c00246272.gif
  6. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  7. Reinstall the cartridge, plug in the power cord, close the printer cover, and then try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step four: Reset the printer
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
  2. Open the cover of the printer and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message.
  4. Disconnect the power cord from the back of the printer and wait for one minute.
  5. Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step five: Replace the cartridge If after you have completed these steps you are still unable to resolve the issue, replace the cartridge. If you do not have a replacement print cartridge, go to the next step. Step six: Print in backup mode If you do not have a replacement print cartridge, you can still print in ink backup mode until the issue is resolved. Remove the problem cartridge and print with the remaining cartridge.
  • If you remove the tri-color cartridge, the printouts will be in grayscale.
  • If after you have completed these steps you are still unable to resolve the issue, service the product.
  • If you remove the black or photo cartridge, the printer will print more slowly and the colors in the printouts may differ.
I hope this solution will helpful for you. Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful. THANKS & Keep Using fixya
Jul 28, 2011 | HP PhotoSmart C4180 All-in-One Color...
10.10.00 SUPPLY MEMORY ERROR after every page prints.
This means that the printer is unable to read or find the toner cartridge memory chip. In some cases turning the printer off, removing the toner cartridge, reinstalling the cartridge and turning the printer back on sometimes correct this issue. But if that does not work, you will have to replace the toner cartridge.
Feb 22, 2011 | HP LaserJet 2420 Printer
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
I own a Lexmark 2400. It says align the cartridges has 2 bulls eyes, says print and when I do up comes this option is not available while printer is busy ok help. When I try to cancel out printing...
YOu can try first to unplug the ptinter and remove the cartridges for about 5 minutes and plug it back in, then after that check if you still have the same problem if you still have you can also try to uninstall and reinstall the printer software....
Dec 04, 2008 | Lexmark Office Equipment & Supplies
HP lasrjet 4240n it won't print
The printer is unable to read the electronic information (e-label) on the print cartridge so that the printer can keep track of the page count for the print cartridge.
1.
Open the top cover, remove
the print cartridge, and
reinstall it.
2. Install a new HP print
cartridge.
3. Check the connection
between the
DC controller PCA
(location J97) and the
memory chip on the print
cartridge (location J600).
4. Replace the memory chip
cable and contact assembly.
5. Replace the
DC controller PCA.
Sep 03, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
19 people viewed this question
Ben Johnson
