Question about Kenwood Car Audio & Video
Hi, i have just installed the kenwood kvt 522dvd in my bmw 320d saloon 2006 model. I cant seem to get the dvd player to work as it keeps saying that the parking break is off?
Hi!
I have the same problem.
how to fix it ? is it easy to do that? can i do by my self?
Posted on Aug 01, 2013
Your parking break must be on in order to view video on the screen. its a common safety on most in car dvd screens intended to be installed in-dash
Posted on Aug 28, 2008
I got a kenwood kvt-512 and my ipod seems like it doesnt work ?
go to :- http://kenwood.com/cs/ce/mm/firmware/2008/eng.html
then change the file to an iso and burn to a disc.
put the disc into stereo and press dvd and let the disc do the rest.
hope this helps works on all kvt systems
Dec 31, 2010 | Kenwood KVT-512 Car DVD Player
KENWOOD KVT-729DVD & KCA-BT100 BLUETOOTH + KCA-IP300V
Try this. This is the Kenwood support. Hope this helps. :)
By Phone
(310) 639-9000
or toll free 1-800-KENWOOD (536-9663)
Jan 13, 2008 | Kenwood KVT-617DVD Car DVD Player
Dont know password code baught it off a guy and didnt give me the code
password code is kcar i have the service manual and it tells u there but i cant seem to get ot to work
Jun 23, 2010 | Kenwood KVT-715DVD Car DVD Player
JUST INSTALLED THE KENWOOD KVT-715, AND CANT SEE THE VIDEO BUT I CAN HEAR IT...
check handbrake wire usally green on kenwood depends on counrty, put it to ground
Apr 26, 2010 | Kenwood KVT-715DVD Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 with bluetooth setup troubles
Mar 02, 2009 | Kenwood KVT-512 Car DVD Player
Bypass parking brake for dvd player Kenwood kvt 512
Just connect the purple safety wire to the car's ground location or to the other ground wires.
Dec 25, 2008 | Kenwood KVT-512 Car DVD Player
Kenwood kvt-729
did you go to the settings and set up a memory checkpoint?
Jun 27, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt 717 dvd
I think this may be it, here: http://www.partstore.com/Part/Kenwood/Kenwood/KVT717DVD/Kenwood/Kenwood/J84015005/New.aspx If not, do a search for your model number on the same site. They have over 100 replacement parts for that model.
Jul 13, 2007 | Kenwood KVT-717DVD Car DVD Player
Car Audio & Video Logo
296 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
