Question about Pentax *ist D Digital Camera
*ist D, Microdrive problem
This has been hinted at in other threads, but could someone go into detail about how he's had success extracting a microdrive from the *ist D? My 384MB version is absolutely stuck. I've tried various methods for a couple hours, and I cannot get it out. What a terrible design! (Great camera otherwise).
    Master:
  • 542 Answers
I've been using the microdrive with *Ist without any problems. To remove it, I am using my fingernail to pull it out, sticking it in the grooves at the at the edge of the drive. However it may be difficult if you have large fingers. You may want to try the same trick with the pen of a toothpick. I also read that some people make a "handle" out of the scotch tape. If your card really stuck, the only solution would be needlenose pliers.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
I'm afraid the best(?) tip means you put a piece of tape on the MD before you put it in the camera. That way you have something bigger (well...) to hold on to to pull out the MD. If I were you, I'd place something soft on a table (to catch the MD falling), find a pen, tilt the camera with the CF compartment facing down and try to push the eject button with the pen (being out of the way for the MD). Hopefully this will be enough. I really don't have any other ideas and I haven't any problems with getting my CF cards or my MD out of the camera (yet?).
On the lower loop blue keeps breaking
Looper thread breakage occurs frequently when the thread path is incorrect or threaded out of order. Most machine must thread the upper looper first, then the lower looper. The lower looper thread ends "draped over" the upper looper in the last step before being pulled toward the back of the machine and under the presser foot.
Another common cause is tension that is too tight.
VERIFY the thread path is correct for every thread!!!! Missing a thread guide or looping around a guide will throw your machine for a "loop."
Another hint, when threading, ALWAYS RAISE the presser foot throughout the process and be sure to give each thread an "extra little tug" when going through the tension to make sure it is seated completely. Sometimes, the thread will even "pop" when it seats. When a thread break, checks that the thread has not "jumped" out of a thread guide or the tension disk.
If the thread breaks, it is usually less frustrating (in the long run) if you remove ALL the thread and start over from the beginning. Trying to snake a broken thread out of order through the sequence is frequently 99% UNsuccessful!!! It takes a lot of familiarity with your machine to be successful threading out of order, but there is still a lot of room for failure!!!
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH
Make It Handmade How to Thread Your Serger Out of Order
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
Nov 17, 2016 | Sewing Machines
How do I thread bobbin and needle on a New Home 656A
New Home is no longer a brand name but you can find some basic instructions online. HINT: It usually helps to raise the presser foot during the threading process--allows the tension disk to release so the thread will seat properly.
Perhaps this will help:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Although it does not show your model, a lot of models operated similarly except some had more options, ie embroidery stitches, etc.
New Home Model 532 Sewing Machine Threading Diagram
Here's a manual for a 539:
http://www.archive.org/details/NewHome539SewingMachineOwnersManual
May 03, 2016 | New Home Sewing Machines
What does the card error mean
Can be lots of things. Would have been handy, if you had told what card you are using. Your camera can work with CompactFlash, Microdrive and xD-Picture cards.
If you did not insert the card(s) you are using, correct, or you removed the card in a wrong way, you could have damaged the cardholder, causing an error you probably can't repair yourself. The CF and Microdrive you can remove by pressing the eject button. The xD-Picture card you can remove by pressing in the card, and release it. The card comes out.
Then you could have damaged the file system, by opening the card cover, while the card access lamp was blinking. What ever card was in, the filesystem can be damaged.
Then you can have two cards in, Both, o CF of Microdrive and a xD picture card. Some settings are required for the camera, to know hat card it should use.
If you have an Microdrive, the drive can be damaged, by a magnetic file, or the drive just stopped rotating. A micro drive is actual a miniature spinning hard drive.
First check if the memory card is inserted correct. Eventually, remove it and check all contacts, on the card and in the camera. Then try formatting the card. If you think there could be important pictures on the card, put it in a external card reader and use a recovery program, to see you can recover the pictures on your computer. Programs can be found on the net.
If you can't format the card, check if you have a Microdrive. If so, try to replace that with a CF or xD card.
I hope something is to any use for you.
Next time, please give us some more details. I know you exactly see and know what is not working, but we only can use your description. And only what you give us.
Feb 16, 2014 | Olympus E Cameras
Where do I put the microdrive?
You saw that the microdrive fits where the memory card goes?
FixYa currently doesn't have a way for us to delete questions once they're posted. They want to keep the questions and their answers up for posterity, in case the answer might help somebody else in the future.
Jan 23, 2014 | Canon Rebel XT / EOS 350D Digital Camera
When someone send files thru bluetooth successfully,the received files it says empty ..plz help
Here let me give you a hint.First try to make back up all the important files which is stored in your phone memory and restore it by using *#7780#.However,if the problem still persist format it by using the code *#7370#.Thats you need to do it by yourself and I can guarantee you that it will surely works.Good luck
Feb 07, 2012 | Nokia C3 Cell Phone
Problems threading my janome serger
One critical hint:
You must thread the loopers BEFORE the needles, otherwise it won't stitch. Begin with upper looper, lower looper, right needle then left needle.
Jan 16, 2010 | Sewing Machines
Microdrive compatible?
The microdrive is compatable with anything that supports reading compact flash memory cards, because there is a common method of communication between flash and hard drives that use pcmcia or CF slots.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Remaining images counter problem on *ist D
I've had this problem... it was, of course, the quality setting which was reduced to lowest by whoever was doing the repair. I have never used this setting almost always using the *** setting or RAW. When I set these I get the kind of numbers I was used to in my remaining images counter. I am so glad I came on this forum and now the only fly in my ointment is the embarassment I feel for not having spotted the problem and the realisation that this may have been the problem before and I need not have sent my camera off on the second occasion.
Sep 08, 2005 | Pentax *ist D Digital Camera
Microdrive
The E-20N power supply circuitry is designed differently from the power supply circuitry of the E-10, enabling it to work with the IBM Microdrive.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
IBM Microdrive
Yes, the E-20N digital camera can use a type 1 or type 2 Compact Flash and the IBM Microdrive.
Pentax *ist D Digital Camera Logo
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
