Question about Canon S520 InkJet Photo Printer
7 orage light blink on my canon s520 printer
Putting new ink in .. it keep repeating same problem don't know how to fix it
Take printer head and cartridges out - remove cartridges - wash printer head in hot /warm water for 30 mins - dry - place 5 drops of alcohol- metho - no drinking - on each noozle and let stand for 5mins. wash printer head in clean hot water for 10 mins - dry - clean outlets of cartridges with 3 drops alcohol - hic - remove scum layer until colour shows ie black,cyan, magenta & yellow - set into printer - set test page - stand back and admire the quality print of your new printer - RC
Posted on Sep 19, 2008
Canon S520 Printer won't print black!
Hi.
Remove Black cartridge,
make sure its not dry, if that's ok make sure that the small air vent is not blocked (hard to find sometimes)
Dec 30, 2017 | Canon S520 InkJet Printer
The s520 printer will not print in black. ALl the
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | Canon S520 InkJet Photo Printer
Canon S520 Won't Re-Set after installation of new Canon waste ink absorbers
plz check the website
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Jun 30, 2008 | Canon S520 InkJet Photo Printer
Canon s520
I had the same problem. tried resetting the "waste ink tank" counter and it didn't work. I ended up taking out the printhead (pull up on the Grey lever) when I put it back in the printer worked! Good Luck!
Apr 27, 2008 | Canon S520 InkJet Photo Printer
Canon S520 Printer
try powering it down for a couple of hours for a full reset.
Mar 03, 2008 | Canon S520 InkJet Photo Printer
Canon s520 problem
I solve mine (4 Yellow Flash + 1 Green) by pushing on the white gear, located at the end right inside, where the cartridges are cleaning. This help the movement of the gear, it was stuck or gem. Do this when you just turning on the printer, then you ear the cycle noise, Your fingers will sense the movement of the gear. Tips: Push the cartridges block to the left to let you enough space to put your hand inside.Now it work normally.
Feb 12, 2008 | Canon S520 InkJet Photo Printer
S520 will not print in any color
If you have tried to print a nozzle check page and no ink has been deposited on the page, then it might be a bad logic board inside the printer or a faulty purge unit. Both parts are relatively expensive to purchase. You might be better off looking for a used Canon s520, i550, i850, pixma 3000, or similar model to use the remaining ink cartridges if you can locate one in good condition and not more than 40 USD. xcd187
Oct 03, 2007 | Canon S520 InkJet Photo Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
314 people viewed this question
old marine
old marine
