Question about Nokia N95 Cellular Phone
Help!! pls hi there, in your solution to formatting the n95 you wrote: * + 3 + Calling key + On/Off key till formatting appear, Other wise flash ur phone That doesn't work for me...what does flash your phone mean? trash it? thanks
  • 1,234 Answers
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 28, 2010
The n6600 is turning on properly but after a few seconds it turns white screen only and keypad lights turn off and turns on when power button is pressed.,.,how can i repair it?please help me.,.,
The Problem is with your 6600 Software just Flash it (renew mobile software)
// Feel free to vote this answer with 4 thumbs up //
Jun 16, 2011 | Nokia 6600
My nokia 6600 is sending bluetooth messages on it`s own
hi its a very common problem with 6600. u should flash ur mobile from a certified mechenic.OR u must try this method: first switch off ur mobile and switch on ur set while pressing (star key),(dial key or green key)and(number 3 key) till formating screen appear.after appearing formating screen leave the button and let format ur handset.
plzz rate me
Dec 22, 2008 | Nokia 6600
Phone start up failed
if it is a series 60 phone than try holding the following keys together (1);-green key(calling key)
(2);- 3
(3);- *
(4);- on\off switch
keep holding them till it shows formatting the will take some time then it will restart ur battery must be charged for this process
May 23, 2008 | Nokia 6630 Cellular Phone
Unlocking n95 8gb
try three key format it will unlock all and gets in factory defaults
in off state press calling (green button)+*+3 and on your cell while pressing all menshoned keys till your phone display shows formatting try this it works
Apr 17, 2008 | Nokia N95 Cellular Phone
How can i format nokia n95
you can go to the nokia update service and cn reflash the software
Apr 01, 2008 | Nokia N95 Cellular Phone
My N95 cellfon hung upon viewing songs, picture and images!!
hi there OWEE hope this will work for you. its a software problem
here's the tricks:
backup contacts first. then
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till NOKIA LOGO appears then release. finish, phone will be ok. you will know that you successfully format the phone cuz' all your data form the phone will be back to normal.
Mar 28, 2008 | Nokia N95 Cellular Phone
N93 problem
Make sure to always switch off your phone by pressing the On/Off switch.
Before receiving or sending files via bluetooth, press the menu button for 2 seconds, this will show you how many applications are in use, press C to switch them off, (except bluetooth).
Check that your phone memory isn't over full with pics, videos etc...
You could try a reset input:
*#7780# Restores factory settings.
Jan 12, 2008 | Nokia N95 Cellular Phone
N70 phone lock code fogotten
Try a reset:
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn phone on. Keep them pressed untill the reset screen appears.
Give it time to reset.
Jan 10, 2008 | Nokia N70 Cellular Phone
Format N95
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
Nov 16, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
16 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
