Question about Pentax *ist D Digital Camera
Power-up problem with *istD
I have had a recurring problem with my *istD that I hope is easily corrected (not likely), or at least confined to my camera alone. I have had the camera since late September, and the following problem has only occurred on the three days where I was taking pictures in the field. Indoor and documentation photography have never caused the problem. I have shot thousands of photos. Two weeks ago I shot over 200 pages of a rare book in about an hour. Symptoms: The camera will not complete power-up. When it is switched on, a double-click, repeating about every two seconds can be heard (sounds like a wind-up clock), and the LCD remains blank. On a few occasions on these days, the camera completes start-up after a few seconds of clicking. More commonly, it will continue to refuse to start. On each occasion, the camera starts after being left off for a while. I have gone through several such cycles in the last two days, and previously on a field trip in mid-March. Sometimes, this also happens when the camera is on. I think it is still a power-up problem after the camera is in sleep mode. In two particular instances, the camera was on and the mirror remained locked up when the shutter release was pressed. At those times, I had to remove the batteries to get the shutter to close and the camera would not start. In each case, I was carrying the camera, and had been shooting before the lockup occurred. I've tried changing batteries, CF card, and the watch battery to no avail. In each case, the ambient temperature was 80-90 degrees. My present impression is that this is a heat problem (not from the batteries). If this is a general design flaw in the *istD, some of us are in for a lot of trouble later in the year. I have just reloaded the latest firmware to see if that helps (desperation time). Unfortunately, I just went on vacation to do some photography across Southern California and Nevada. Not a good time to find this problem with the camera. I would appreciate any comments or suggestions. I may not reply until I get back next Sunday. If the problem cannot be resolved, I guess I send the camera in for repair. I hope it is not a general design flaw.
    Master:
  • 542 Answers
Chances are that this is real problem of electronics... not unusual with these devices...However, what is missing from your story is what preceded the appearnace of the problem. Was the camera exposed to high humidity? was it dropped on the floor from 20 feet? anything?
Posted on Sep 08, 2005
Batteries not registering
This is a common problem with this model...happens to me too. I find that turning it off and then on corrects it for awhile.
Mar 25, 2010 | Pentax *ist D Digital Camera
Tip
Cyberhome CH-DVD300 DVD Player
Symptom: Unit will not power up at all. Power indicator doesn't work.
or after inserting disk, screen says "loading disk" but then
says "bad disk".
Solution: This problem is usually caused by a bad 5Volt power supply.
Check the 5V output of the power supply board. The output
plug is clearly marked. If this 5V is less than 4V, the unit will
not operate. This is caused by defective filter capacitors in the
5V supply. These caps are easily identified. Replace these
two with the same values and the 5V should return to normal.
Note: Because of the confined spaces on the board, only use caps
that are of the same physical size. Capacitors are made in a
varity of hights and diameters with the same electrical
specifications. Do not try to pigtail a larger cap in circuit. The
circuit will not work correctly. I can supply these if you can not
find them locally.
on Mar 28, 2010 | Cyberhome CH-DVD 300 DVD Player
Can I re-mount thot shoe that went off my Pentax *istD by myself?
Its it a good camera. So dont try to re-mount the hot shoe by your self. Please contact Pentax service center.
Feb 01, 2010 | Cameras
When i turn on computer i get a recurring beep does not boot up
The most common reason for a recurring beep is a hardware problem. Remove all the memory modules and install one at a time to test.
Also, if your keyboard and mouse have PS/2 connectors (round, rather than USB), be certain that they are connected correctly to their ports.
Hope this helps.
Sep 06, 2009 | Foxconn 6100M2MA-RS2H Motherboard
*istD pop-up flash problem
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Sep 08, 2005 | Pentax *ist D Digital Camera
IstD LCD Screen...Problem
Resolution on the LCD is rather "rough," but I think all these tiny screens are that way. Considering the "roughness" of the photos in playback, and their sharpness when viewed full on on a computer, the text is about up to as good as this screen can produce. Or, in other words, I'm see'in what your see'in as for text. I think it's just normal.
Problem with AF-360FGZ Flash
Yes. The *istD shutter can only provide X-sync for electronic flash up to 1/150 sec. The *istDS reaches 1/180 sec. "High speed" electronic flash is done by strobing the flash repeatedly during the period that the shutter slit is traveling across the focal plane, at th expense of cutting power output quite a bit.
Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
IstD problem selecting recorded pixels and RAW/Tiff/jpg
I'm not sure what could cause this, in fact I don't even own the D but..... Approcahing this from a Network Analyst's poiunt of view, it's either hardware or software. The fact that all other modes are OK would indicate that the hardware may be ok. Assuming that it's a software glitch have you tried installing the latest firmware ? It may be worth a try if your problem is a result of some corruption your exisiting fw. It'll cost you nothing to try it anyway.
Exposure problem
I've found that the *istD underexposes ( as it should metering 18% grey ) light subjects, or with light backgrounds. A white wall using TTL ( AF500ftz ) behind any subject it always turns grey! You need to manually adjust 1 stop over. With dark subjects, overexposing with out blowing out much. If your used to the metering from a PS digi cam the *istD takes a bit of getting used to.
Pentax *ist D Digital Camera Logo
70 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
