Question about Lexmark X1240 All-In-One InkJet Printer
Blank page My printer is printing blank pages. My ink cartridges are full and the tape has been removed. They are also installed properly. What could be the problem?
    Problem Solver:
  • 19 Answers
Check to make sure the ink carts are actually expelling ink. To do so take them out, get a piece of paper towel and press the ink cart onto the bottom of the cart ( where the ink comes out ). If the ink comes out and you see the colors, Open the Lexmark Solution Center, click on Maintance, and click on "clean horizontal streak". If that does not work then chances are they are clogged and you will need to replace the printer. You can do so through Lexmark Tech Support if the printer is within the 1 year Warranty
Posted on Aug 29, 2008
1. Did it ever 'properly' print pages....?
2. If so, is there enough ink in the printer? You have be able to tell in the printer's program....
3. If you just changed the ink cartridges, or this is a new install, did you remove the pieces of shipping tape, on the back/bottom of the cartridges?
What have you tried, "Everything I can..."..?
Feb 12, 2015 | Brother HL-4040CN Laser Printer
My Kodak printer is only printing out blank pages. I just put in new ink cartridges today, but nothing is printed on the pages.
the cartridges come with tape over the print heads to keep them from leaking during shipping.
Remove the tape and put the cartridges back in.
Aug 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Nov 29, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer will not print in black
I will try to help but when you installed the printer and the cartridges, did you remove meaning completely remove the tape on the printed circuit and nozzles of the cartridge? Did you remove all the tapes on the machine? It's not likely that the cartridge is defective when it is that new. Hope this helps.
Nov 17, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
I keep getting cartridge error or it prints a blank page. There is no tape on the cartridge and they are installed properly. It prints sometimes but not all the time Printer keeps saying cartridge error
This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
Aug 26, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Jan 05, 2008 | HP DeskJet 880c InkJet Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
Lexmark X1240 All-In-One InkJet Printer Logo
215 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
