Question about Panasonic Vacuums
I need to replace the "hose assembly" for a PANASONIC MC-E852. wHERE CAN i GET ONE? Ykanks
I bought a new one.
Posted on Aug 29, 2008
How do I improve suction of the Panasonic mc cl310 vacuum
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the hose and canister to make sure nothing is lodged in them. If nothing is there and it does not fix the problem, your issue could be related to your brush-roll. Check your brush-roll to make sure that nothing is interfering with it. If that does not solve the issue, the next area that should be checked is your vacuums filters. Filters should be replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement Panasonic vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Panasonic MCCL310 MC-CL310 MC CL310...
Need part number for hose alone for panasonic MCV9610
The following hose fits models MC-V9610, MC-V9620, MC-V9635, MC-V9647.
It can be found at: http://www.pasc.panasonic.com/epartr/PartsListChoice.asp?validate=1
AMC94P-GEZV004
Jan 08, 2011 | Panasonic Vacuums
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
What belt does the Panasonic MC-V7380 Vacuum take?
Here is a link to the belts you need for your model and the manual which has instructions:
Panasonic MC-V7380 Belts and Manual
Dec 12, 2009 | Panasonic MC-V7380 Vacuum
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Panasonic Stow'n'Go, model MC-V5481
If you turn the vacuum over, you will see a hose by the brushroll. I think your problem is that it's stopped up right there. Take off the brushroll and make sure that the hose isn't stopped up. The port at the back that makes a hissing sound is to indicate that it's stopped up somewhere. Also, when you replace your attachment hose back onto the machine, does the motor change sound?? That's also another indication that your machine is stopped up. Don't lose hope for the Panasonic, they're great machines. If you still need help, you may call us at 1-866-509-1952. Thanks.
Jul 10, 2007 | Panasonic MC-V7600 Bagless Upright...
Vacuums Logo
43 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
