Question about Coleman Campfire Grill
Coleman stove (Coleman fuel only). Won't stay lit. I have taken pump tube apart, seems OK; soaked tank in denatured alcohol (to remove lacquer buildup). Lights OK but goes out -- can still hear fuel moving through generator.
  • margarb Sep 25, 2008
    Thanks for responding Dwight! This is a Coleman fuel stove, so only uses Coleman (white gas) fuel in a refillable tank. The fuel flows when pressurized by pumping air into the fuel tank.
Try screwing the needle valve in all the way. Carbon builds up in the generator and if a piece got loose, it's clogging the small hole at the end. Turning the valve in all the way might free it.
If that doesn't work, you'll need to purchase a new generator tube.
Posted on Feb 23, 2009
    Problem Solver:
  • 10 Answers
Is it possible that the part that screws into the propane cylinder is not opening the bottle all the way. This would alow enough gas to flow through to light but will not keep a flame because there is just not enough fuel flow. If this is the case you most likely can't fix it and need a new one. How old is it, if you can return it for a new one, do that, just to be on the safe side.
Posted on Sep 24, 2008
  • Dwight Sep 25, 2008
    Woops, should have read more carefully when you wrote Coleman fuel only.
How to get water out of a gas tank
If it is allot of water you will need to pull the tank, if the water is muddy you will need to pull the tank. If it is just a little water you can pump it out by using the in tank electric fuel pump by jumping the fuel pump relay and powering up the pump all the time. If the water has been in the tank very long you may have much more serious problems with parts like injectors being ruined from water deposits and rust. In some cases you can absorb the water by adding a pint of denatured alcohol to the tank, it is available from any hardware store.
Jan 16, 2012 | 2002 BMW 5 Series
Coleman model# 2430-730
It is an old one, Propane? or gasoline/camp stove fuel?
If propane and will not remain lit- replace the thremocouple- that thing beside the pilot flame that does not seem to do anything- it holds the gas valve open when flame is present.
If gasoline/camp stove fuel and will not light or does not stay lit- clean the "generator" which is under the asbestos shell. It is not even acknowledged by Coleman anymore.
Dec 22, 2011 | Heating & Cooling
Has been sitting for a year. Won't stay running. Not getting gas. Float bowl was emptied and new fuel put in. HELP!
You will need to remove the carb and clean it. Remove the float bowl and clean the interior of the bowl and the interior of the carb body. Soak the entire carb, (with bowl removed), in denatured alcohol. Any hardware store will have it. Let it soak for an hour. Then clean it with spray carb cleaner. Spray into every hole you can find. Spray from both ends of the hole if possible, where the spray goes in and where the spray comes out. Pay special attention to the pilot jet (idle circuit), and main jet, (high speed). The diagram below is a generic carb. Please rate my answer.tombones49_212.gif
Jul 24, 2011 | Yamaha DTF 150 Motorcycles
Colman stove won't light
Here's the way these oldies work:
1. Make sure you've got fresh Coleman fuel or equivalent in the tank.
2. Make sure the cap is tight on the tank.
3. Unscrew the pump knob counterclockwise about 1/2 to 3/4 of a turn.
4. With your thumb covering the hole on the pump, pump the tank about 15-20 times, then screw the pump handle tight clockwise.
Then you can turn the little lever knob to the light position (I believe it is in the up position) and then crack the fuel knob open a bit and attempt a light of the burner with a lit match. As it warms up you can turn the lever to the opposite position to obtain a good flame...
Best to try this before you leave for your trip...
May 29, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
My coleman 424 stove has been sitting in shed for a coulpe of years, now got it out again. Filled with petrol when pumped up I can light it but flame only lasts a few minutes then it dies as if no...
My best answer is that your pump seals have dried out and are allowing pumped up pressure to leak back past the pump seal
Try this: DO NOT LIGHT THE STOVE
Pump it up hard then quickly attach a small balloon with a rubber band around the base of the pump - where it contacts the tank. A deflated balloon or a small plastic baggie - does the balloon begin to fill with air after a few minutes - if yes then your seal is leaking.
You might try taking the pump apart and soaking the seal overnight in fuel reinstall and see if it cores your problem
Good Luck
Mar 22, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman Peak 1 400A fuel/air mix wont ignite
krimkramm, any luck finding a solution? www.spiritburner.com seems to be a great source of information if you are still trying to fix your Coleman 400A. If you would like to sell it, I am looking for one for my local Boy Scout troop. Send me an email at braddotroberson@verizondotnet after replacing the dots with a you-know-what.
Brad
Aug 10, 2009 | Kitchen Ranges
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 425 2-burner white gas stove pops out flame on low heat
There is water in your fuel. Drain the tank and flush it out with denatured alcohol. Refill with fresh fuel.
Jun 21, 2009 | Coleman Sport & Outdoor - Others
Coleman Peak 1 Model 400 stove We have had this stove for 20 years at least. The last couple years a problem has begun and has gotten worse. The stove will leak liquid fuel all over the base which then...
I have heard two things that could improve your stove. I had the same "bursting into flame" issue last weekend while camping. First, move the black handle back and forth a few times. That is supposed to clean the jet. Second, take the generator off and hit it with a blowtorch. That should clean out the deposites on the inside. Or you can purchase new generators (just make sure you get the correct one).
Aug 03, 2008 | Kitchen Ranges
Rough age 1960s coleman catalitic heater. round green with a domed top.
the coleman uses a vermiculite "sponge" in the dome. after you pump it up and start it, there should be a quarter to half dollar area on the dome that gets saturated with fuel. you light this area then open the valve all the way. the entire dome should glow orange.
May 17, 2008 | Coleman 5031-750 Utility Heater
Open Questions:
Coleman Campfire Grill Logo
499 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
