Question about Pentax *ist D Digital Camera
*istD battery problem
I had a weird problem this weekend while shooting a wedding. I had replaced my batteries with new EnergizerAA lithiums before the wedding,after about 50 shots, I get the "battery depleted" error on the LCD. I then changed those batteries(thinking maybe theyre defective) and about 100 shots into the new ones, same thing('battery depleted'). I then switched the camera off and back on, and the thing worked again for like 100 more shots, then the same error. Turn off/back on, it works again. Has anyone else seen this with the *istD? ps. I dont recall getting the 'battery low' warning light on the display panel, I think it just died both times. I really doubt its the batteries since it works for a good while again after powering off/on.
    Master:
  • 542 Answers
I had the same problem with my cell phone last week. Left the wall wart at home (by accident) . Battery went dead and I plugged in the spare. That battery went dead and I plugged the first one back in. It came up happy and ran all day. Next day I switched again. I figure I got two hard days out of "dead" Lithium Ion batteries.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
I use the Ray O Vac IC3 15 minute Nimh and they work great. $30 for 4 and a charger.
    Master:
  • 542 Answers
Battery charge indicators don't measure actual charge but voltage because there is no cost-efficient method to measure battey charge directly. Instead, batteries are designed so that voltage goes down with charge. Now, the difficult thing is that not all batteries behave in the same manner. It is actually very hard to predict how a battery menufactured by xyz behaves. I would guess that Pentax engineers did not have Energizer AA's in their mind when they defined the voltage alert level. I would suspect that the battery status indicator is calibrated for the CR-V3 batteries that were included with the camera body, or something else. Only wild guesses above... And yes, I have encountered weird inidicator behavior with AA batteries, too. But not with CR-V3. I bet your mobile phone battery indicator plays tricks, too.
SOURCE:
What batteries can i use instead of smashing batteries? Duracell ?
That camera takes lithium batteries. Duracell are DL123. Others are Energizer CR123 or Rayovac CR123A. The 123 is the key here. Other makers of lithium disposable batteries will use different letters, but the 123 is what you're looking for. They should still be available at Walmart etc. Panasonic CR 123APA 1B CR 123A Photo Lithium Battery Retail Pack Single
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
I am unable to get a new battery for Canon Cure Chot ZOOM-S. Please can you help?
The Sure Shot Zoom S uses a 2CR5 6V lithium battery. You should be able to find one at an electronics or office-supply store. If all else fails,
http://www.batteriesplus.com/product_search/31018-Rayovac-2CR5-Lithium-Battery-1-Pack-DASH--DASH-RAYRL2CR5--1.aspx
Aug 24, 2010 | Canon Sure Shot 105 Zoom S 35mm Point and...
The ready light never turns green, it just stays red. Will not flash. Could it be that the bulb needs replacing, and can that be done by me? I have a wedding next weekend, and really need to have it by...
The ready light is not supposed to turn green,it only glows red.
For a start check the trouble shooting guide in the User Manual - page 84 - 86 to see if this helps.
The flash tube needs to be changed by a Nikon Service Centre
Mar 18, 2010 | Nikon Speedlight SB-600 TTL Flash
Screen says Replace Battery after 20 minutes of being powered on
Try rechargeable batteries if your are using AAA or AA. Some cameras just stop working with the one-use batteries. If you have a lithium or other specialty battery, try getting another battery. Your battery may need to be replaced. I shoot a professional grade camera. I can shoot a whole wedding and part of the reception on one set of batteries. The brand I use is called Eneloop. You can't go wrong with these rechargeable batteries. The can be found at any place that sells camera supplies or off Ebay. They typically cost about $12 for 4 AA's. Best wishes.
Aug 29, 2009 | Moultrie MFH-DGS-100 Digital Camera
Quantum Turbo Battery pack not enough power.
Load 4AA with Energizer Lithium Batteries.
Set 580EX II's function to 12-0 and 05-0.
Make sure 5D's is not set to HSS.
No white dome parked on flash.
No bounce.
Set camera to "M" with max sync if you like, but 60 is fine.
Set F-Stop no greater than F5.6
Set ASA/ISO no lower than 200 but not over 1000.
If you need more assistance, contact Alzo Digital, CT, USA.
Asks for service & repair from ATG.
Apr 08, 2017 | Canon SPEEDLITE 580EX TTL Flash
Replacement battery
takes 2 AA batteries, if this is a vivitar camera, ordinary one not lithium
hope this helps
Aug 08, 2008 | Vivitar 450PZ 35mm Point and Shoot Camera
Camera won't power up
I just experienced the same problem. Saturday I was playing with it, shut it off put it away. Sunday came it was completed dead with fully charged batteries and a new lithium battery it won't power up and I've got a wedding to shoot next week. What do I do?
Jul 18, 2008 | Canon Rebel XT / EOS 350D Digital Camera
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
*istD Problem with Vertical Grip
Digital cameras require a large 'surge' of power when performing things like processing an image and saving it to the memory card. Alkaline batteries work best when used in a device that draws power at a steady rate. They do not work as well when asked to provide a surge of power. Your batteries are indeed not dead, but they are sufficiently depleted that they can no longer provide that surge that the camera requires. Take them out and put them in something like a TV remote or a radio. They probably have quite a bit of life left. NiHM and Lithium based batteries are much better at being able to provide the amount of current needed right up until they go dead. The 100 shots you got out of your Alkalines is at the high end of what you can typically with Alkalines in your camera. The continuous shooting could be a symptom of the batteries getting low. Another option to those previously listed are AA Lithium batteries which are cheaper than CR-V3's and last nearly as long. They are not rechargeable though.
Sep 08, 2005 | Pentax *ist D Digital Camera
Pentax *ist D Digital Camera Logo
157 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
