I can't figure out how to set up my fax machine so it won't mess up my phone and answering machine either.
  • fancyhands Aug 28, 2008
    What do I do then if the fax machine and the answering machine are in different rooms? Thanks for the previous answer, it's helpful!!
  • 329 Answers
Telephone wire goes to fax, out to answer machine, Important to set fax on answer machine mode and set the ring count to pick up AFTER the telephone answer machine. Set fax ring count to 5 rings, and answering machine to 3 or 4. When some one calls answer machine or you pick up first, then if no one will leave a msg. fax tones are different than voice tones, they are called CNG tones. Most new fax machine will sense this and if a fax will go to fax only. Ring count is the key. Also you could set fax up for maual mode and would not jump to anser machine or fax till you want.....good luck
Posted on Aug 28, 2008
A fax machine is just a big ol' telephone answering machine
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy
If it doesn't answer, it's not set to AUTO RECEIVE
If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
It's all that SIMPLE !!
on Mar 09, 2010 | Office Equipment & Supplies
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Got new hp elite m9402f computer but new hp fax doesnt answer
hi there,
initially you have to check and correct this few settings.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the main tray.
2. Remove any originals from the document feeder tray.
3. Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers. Or, turn off the Auto Answer setting so
that the device does not automatically answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press the left arrow or the right arrow to select Fax B&W or Color fax.
b. Press Start.
c. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Hope this initial info helps you.
Jan 19, 2009 | HP J4680 Office Jet All-In-One Printer
Cannot answer a incoming call
Make sure that if you DO NOT subscribe to DISTINCTIVE RING that it is set to the OFF SETTING! had to figure this out on my own!
Dec 18, 2008 | Sharp INKJET FAX UX-A1000
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Lands Phones
Can't get this fax machine to work with my answering machine
I have the same problem. I can send a fax, but if I try to receive a fax, the distinctive ring goes off, and it says RECEIVE on the display, but it doesn't receive anything, and there is nothing in the memory. Any ideas? PLEASE HELP!!!!!
May 24, 2008 | HP 640 Inkjet Fax Machine
The short answer is no. The JX200 will work with an answering machine because it "listens in" when the answering machine picks up a call. It can't "listen in" to voice mail, because the voice mail is handled by your phone service.
Mar 29, 2008 | Canon FAX-JX200
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
223 people viewed this question
