Question about Pentax *ist D Digital Camera
*istD pop-up flash problem
Recently, once i pop-up the built-in flash, the tiny *istD will say battery low and not allow me to fire ... ... (of course even with fully charged battery) any idea on what's the problem ???
    Master:
  • 542 Answers
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Posted on Sep 08, 2005
Pentax istd built in flash goes off when taking picture but picture is underexposed but if I use a different flash in manual mode the camera works ok
What distance are the subjects when using the built-in flash?
The built-in flash is optimized for use between 0.7m (2.3ft) and 4m (13ft).
You could also try adjusting the ISO setting (higher ISO requires less light) or adjusting the EV value to a positive number to increase the exposure.
May 14, 2010 | Pentax *ist DL Digital Camera
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Built in speedlight on nikon d70 has stopped working. The light pops up, but no flash
If flash pops up and doesn't fire, little white pin/lever inside flash has lodged up inside flash casing and needs to be eased from where it is stuck. Careful when opening the flash up to dislodge the white plastic pin/lever, there are tiny wires you REALLY don't want to damage....
See how, with pics here:
http://www.stephanmantler.com/blog/d70s-camera-repair/
Sep 12, 2009 | Nikon D70s Digital Camera
Built-in flash does not fire off
Not really a solution, and about 3 years late :) my EOS400D also developed the same problem (however it was also coincidence that I had just updated to Firmware 1.1.1 (from 1.0.4), but basically the flash would pop up, but wouldn't fire (so not the standard problem with the microswitches), I found with a bit of forum searching that if you hold the flash down to almost clicking it in and then shoot it does actually fire. I am going to see how much it costs to get this fixed and will post what the actual fault is if I can understand the repairman.
Mar 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
IstD LCD Screen...Problem
Resolution on the LCD is rather "rough," but I think all these tiny screens are that way. Considering the "roughness" of the photos in playback, and their sharpness when viewed full on on a computer, the text is about up to as good as this screen can produce. Or, in other words, I'm see'in what your see'in as for text. I think it's just normal.
Sep 08, 2005 | Pentax *ist D Digital Camera
Problem with AF-360FGZ Flash
Yes. The *istD shutter can only provide X-sync for electronic flash up to 1/150 sec. The *istDS reaches 1/180 sec. "High speed" electronic flash is done by strobing the flash repeatedly during the period that the shutter slit is traveling across the focal plane, at th expense of cutting power output quite a bit.
Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
Flash problem
That is normal operation, if poped up, the flash fires rapidily in low light to assist the auto focus, on a plain white wall, it can't focus, see the manual on AUto Focus limitations.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Exposure problem
I've found that the *istD underexposes ( as it should metering 18% grey ) light subjects, or with light backgrounds. A white wall using TTL ( AF500ftz ) behind any subject it always turns grey! You need to manually adjust 1 stop over. With dark subjects, overexposing with out blowing out much. If your used to the metering from a PS digi cam the *istD takes a bit of getting used to.
A sliding pop-up system
A new flash mechanism that slides forward as it pops up assures an adequate angle of illumination while contributing to the camera's low-profile body design. The flash offers broad, even coverage with minimal illumination drop-off at the periphery. In addition, the new design allows a dedicated external flash to be used in tandem with the built-in flash.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Pentax *ist D Digital Camera Logo
132 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
