Question about Ricoh Office Equipment & Supplies
REPALCE RICOH MP 161 PCL 6 PHOTOCONDUCTOR UNIT
drichards
  • 87 Answers
SOURCE: RICOH PHOTOCONDUCTOR UNIT CLEAR
Actually, there isn't one! But, you can get rid of the message. Press clear modes, 1,0,7, and then press and hold clear stop. Choose copy sp. Scroll to 5, (mode) then scroll to PCU alarm setting. There are 2 options. Display will shut the message off. If it is a 1, make it 0, or vice versa. Interval, will set the count. You can make it an 80, and that will give you 20000 more prints. Personally, I would change the PCU really soon, other wise you will pay for it in toner.
Posted on Mar 19, 2008
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
  • 86 Answers
SOURCE: Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
SOURCE: Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Posted on Feb 21, 2009
Matt_Sr
  • 31 Answers
SOURCE: I am trying to set up my Ricoh mp 161 to scan to
You may need to purchase the PostScript card to do that, generally the Ricoh's don't comunicate with Macs without it, Your local Ricoh dealer should have a "Print Scan" qualified tech that could help you out. I could try to talk you through it, but I don't think this web site has enough space to type it out.
Posted on Oct 10, 2009
How to enter service mode in ricoh aficio mp 161
Service mode is 'Clear-1-0-7-stop (hold stop until machine goes into service mode).
Aug 22, 2012 | Ricoh Aficio MP 161 Black and White Copier
REPLACE PHOTO CONDUCTER ERROR
photoconductor is the main unit in the machine. it has done its life of 60,000 copies so it requires replacing. if you open the front cover. the photoconductor unit is locater beside toner supply unit.
Dec 13, 2010 | Ricoh Aficio MP 161 Black and White Copier
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Using the PCL drivers for our Ricoh Aficio MP 3350
Try using the RPCS (Ricoh's proprietary print driver) for printing from Word, and see if that works any better. You could also try another version of PCL -- if you're using PCL6, try PCL5, for example.
All of the 3350 drivers can be downloaded here (just choose the correct operating system):
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/mp33/mp33en.htm
Dec 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
WHAT RICOH PRINTER IS COMPATABLE TO THE RICOH AFRICIO 1515
The 1515 is compatible to the 161 and the 171, the two newer generations of similar printers. All three use the same toner and photoconductor units, and are set up almost identically.
Nov 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I am trying to set up my Ricoh mp 161 to scan to my mac...need help.
Oct 02, 2009 | Ricoh Aficio MP 161 Black and White Copier
237 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
