Question about Amana Refrigerators
The frig is accumulating water at the top when the door is closed
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Sounds like air is leaking in or it needs freon!
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Mar 31, 2011 | Fisher and Paykel E522BRXFD Stainless...
Freezer door opens when fridge door closes
if you are worried that the freezer is empty....fill it with plastic bottles of water...remember tho,don't fill the bottles completely as frozen water expands.
Jul 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Water is leaking from bottom of frig, supply line is fine. Its seems to be comming from the front end of frig
Check the drains. It may have been clogged by particles from the food accumulated over time. It may also be from the ice that may have accumulated inside, at the panel at the back.
Jun 09, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
How do i take freezer door off a side by side frig that has water/ice options
usally a quick disconnect block for wireing harness on top freezer hing. There will be a water supply tube going up through bottom freezer hinge with a disconnect union fitting close by usally under refrig behind toe grill. once these are disconnected you can then take top hinge off of main part of refrig. by taking screws off on top of upper freezer hinge. you then should be able to lift door off by lifting up on door and water line should slide up and through the bottom hinge.
Feb 27, 2010 | Kenmore Refrigerators
Water under the crisper
it needs a good de frost now as a chunk of ice develped in a line. un plug fridge, let it warm up, use the chance to give it a good cleaning. this should solve the problem.
Nov 04, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
Light not going out in viking frig when door is closed
you have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Nov 26, 2008 | Viking 24 in. Professional Series VUD141...
I have a Maytab MTB2155BR Refrig that's leaking water. The freezer is on top and the water seems to be accumulating in the refrig section under the criper draws. Somehow it then leaks onto the floor. ...
Have you any tears in door gasket or do you see any way air is getting in the door through the door seal gasket?Is your temperature holding .Or have you had to turn it up??
Jun 18, 2008 | Refrigerators
Water acculation in refridgerator.
I had a similar problem with my old hotpoint frig (top freezer, bottom frig). the defrost cycle would come on and melt the ice, but since the drain plug in the back of the freezer below the coils would eventually freeze up closed due to ice accumulation. It got to the point I had to shut down the whole unit and leave it open for around 8 hours to let it naturally melt the ice in the drain tube. I hear a gurgle sound and then a sound of water flowing, so I knew it was now draining again.
Jun 08, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
99 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
