Question about Calculated Industries Construction Master 5 Scientific Calculator
How many gallons of fuel did I start with and end up with
Tank is 45 jin diameter and 12 feet in length it is laying length wise.
If I have 45 in diameter how do i calculate the amount of fluid is in the tank at anyone time?
    Sergeant:
    Champion:
  • 333 Answers
Simple program here and it works under XP.
http://www.areotank.com/ap0090.htm
Cheers
Posted on Aug 28, 2008
I need to know how many gallons of water are in my pool
Formula For Average Gallons In Rectangle, Square Or Freeform Pools:
Length x Width x Average Depth x 7.5 = Total gallons
Formula For Average Gallons In Circular Pools:
Diameter x Diameter x Average Depth x 5.9 = Total gallons
Formula For Average Gallons In Oval Pools:
Length x Width x Average Depth x 5.9 = Total gallons
Formula For Average Depth Of Pools With Slopes:
Shallow End Depth + Deep End Depth Divided by 2 = Average Depth
Jun 18, 2017 | Pool & Spa
The diameter of my tank? I have a 30 foot long tank that hold 12,000 gallons what will it's diameter be?
That would depend on the length of the tank. A very long tank won't have a large diameter, while a short tank will.
Feb 01, 2017 | Cars & Trucks
Have a 2001 bayloner throphey how much fuel it holds
Are you sure you don't have a 2001 Bayliner Trophy? ;>)
7 gallons, but they come in sizes 17 feet to 31 feet and 125HP to 225HP.
2001 Bayliner Trophy Asking Price: $13,999 OR BEST OFFER Condition: Good. Description Location: Ridgewood, New York Seller's Notes: AWESOME BOAT!! Body Style: Power Boat Length: 21 Hull: FIBERGLASS Class: FISH/SKI BOAT Engine: 2010 Hyundai 150 # Engines: one Fuel Capacity: seven gallons Horsepower: 150 VIN: Request the VIN Seller's Comments Great boat, Lots of storage, 270 hours on motor, Well maintained, Reliable, Great for the lake, Depth/Fish/GPS System, Well equipped, Live well, Pump, Anchor, Seats four, Lots of cabin room, Equipped with toilet.
Easiest way is to run it dry with a 1 gallon portable can on board. Stay close to the marina until main tank runs out, top up with the gallon can, and then go to the marina and fill it up. Whatever it takes minus 1 gallon is the capacity. Then refill that gallon can and log how many miles you do on a full tank. I carry 2 x 6 gallon tanks, I know one tank will take my 95 kilometres (I am in Canada)
Red portable fuel marine tanks hold 6 gallons. The size is marked on it. If you have a fixed tank, they are usually 20 gallons, but to be sure use my method and a fill.
Bayliner Trophy 2002
May 14, 2016 | Cars & Trucks
How much will my water tank hold? it`s 65" in diameter and 33" tall
Figure it out this way, the formula for a round vessel is:
(The formula is for "Feet" so make the proper conversion 1st)
you also need to know that there are 7.5 gallons in a cubic foot
Pi x r2 x depth = cubic feet x 7.5 = total gallons
3.14 x (65" = 5.42' diameter, 2.71' = radius {squared} x 2.71 = 7.34 x 2.75 x 7.5 = 475.36 Gallons
Mar 08, 2015 | Water Water Heaters
How many gallons of water in a 24 foot round pool that is 52 inches deep
18,600 gallons (length x width x depthx 7.51 =gallons)
Aug 23, 2014 | Pool & Spa
72in x 29in x 24in how many gallons calculator
72 x 29 x 24 = 50,112 cubic inches / 1728* = 29 cubic feet. There are 7.48 gallons per cubic foot, so the tank is actually 216.92 gallons, assuming the dimensions given are inside measurements. I hope you have a strong stand and floor because the water alone weighs 1735.36 pounds (8 pounds per gallon).
*12 x 12 x 12 = 1728 (cubic inches to cubic feet conversion)
Jul 17, 2014 | Aqueon All Glass Aquarium Co. 210 Gallon...
Need to see gas tube connections inside of bvm 200 vs
larger diameter fuel line leaves the carb from the spigot nearest the primer bulb and terminates just inside the fuel tank. The smaller diameter fuel lines is the main feed. It will have the filter on the end of it and it should lay loosely on the bottom of the fuel tank and go to the spigot on the fuel pump side of the carb.
Nov 10, 2012 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a weedeater xt 200 trimmer. The parts in
The tube in the tank is the fuel pickup line and goes directly to the carburetor. You will need to get NEW fuel lines. Fish or shake the old parts out of the fuel tank after draining. Inside the tank will be a small length of smaller diameter fuel line that connects to the small fuel filter and there will be a small nylon line connector that is plugged into the end of the larger diameter fuel line which is the fuel return line from the primer bulb back to the fuel tank. That line ends just inside the fuel tank and is held there by the small nylon line connector. The other line (smaller diameter) needs some length inside the tank so it can flop around as you move the machine enabling it to always pick up fuel. 6" or so is about right from the hole in the bottom (or top) of the tank to the fuel filter. Buy long enough lengths of fuel line that they can be inserted into the tank and pulled thru the fill cap area and then have the parts put back on them and then cut to the correct length from the fuel tank to the carburetor and/or primer bulb. Buy about 1 foot of each size line needed. Small engine repair shops have it and sell it..not expensive.
Jul 18, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Air compressor line
Three basic methods:
1.Run power to the garage and reclocate the compressor there.
2.Use 3/4" steel or copper pipe run under ground to move the air without loosing as much pressure.
**3. Keep doing what you are doing but...add a portable air tank at the end of the line. I would suggest 11 gallon and add a large diameter 1/2" or 3/4" ID hose that is only 12 feet off of that to reduce the loss of pressure. I even ran a 100 pound propane construction size tank (after cleaning it and refitting it with large diameter pipe) Use a "cross" piple to get air into and out of the tank. Just remove whatever the portable tank has on it and create your own setup. This really works well.
Jun 29, 2009 | Air Tools & Compressors
Calculated Industries Construction Master 5 Scientific Calculator Logo
162 people viewed this question
Top Calculated Industries Office Equipment & Supplies Experts
Vernon Taylor
Joe Garcia
Joe Garcia
voyager663rd
Are you a Calculated Industries Office Equipment and Supply Expert? Answer questions, earn points and help others
