Question about Coleman Roadtrip Grill LXE 9949-750
Burner Knobs stcuk/can't turn
The burner knob on the right side is stuck and it won't turn. I've tried everything and can't get it to work.
  • 1 more comment
  • Anonymous Sep 20, 2008
    same problem here
  • Shamrock2828 Dec 13, 2008
    Right knob on New Coleman roadtrip grill does not not turn. Any help would be appreciated.
  • Anonymous Mar 29, 2009
    Same here, I actually broke the knob right off and not need the part that the knob is attached too. I should have bought that WebBer BBQ
I had the same issue.
Take the lid assembly off and remove the metal shield over the burner controls.
This will allow you to remove the black cover that you see on the front of the grill and will give you access to the burner controls behind the knobs.
there is an almost diamond shaped metal piece with a screw in the top and one in the bottom that the know shaft runs through.. take note how it is currently positioned and then remove the screws and the piece of metal will come off.. dont lose the spring or lock washer.
you will now have access to the valve which is your issue. i sprayed some liquid wrench and i used a large common head screw driver to "beak" the valve to allow it to turn. Test it so you know which position to return the valve to and then put it all back together.
Posted on Jun 05, 2009
I have a 3 burner Weber propane grill. The control knob to the first burner is stuck in the open position ( pressed in and won"t pop back out.) What should I do?
Okay turn off the propane 1st . take the control knob off . Spray the control with wd 40 let this soak in the replace control knob and try and turn it back to the off position this may take a few goes . once this out you will need to grease the plug on the control there should be a screw od screws which holds the plug in . You can remove this and grease it . Be careful when removing do not loose the spring inside you can remove the plug with some longnose pliers , put it back the same way it came out .
Oct 28, 2016 | Heating & Cooling
Broken knob
Turn off the power to the appliance. Squirt WD40 liberally all round the knob, trying to get it in behind it. Wiggle the knob and press it down and up if possible to let the WD40 oil work in to the dirty or stuck joints. Leave for a few hours and wiggle it again to see if its loosened up.
Dec 15, 2013 | KitchenAid 30 in. KECC506R Electric...
No sound of gas
Tyrn off tank open conrtol knobs to burners , turn off burners turn tank on slowly see if gas comes out now , if not check burners are not blocked or injectors are not blocked
Jul 04, 2012 | Grilling
I've used you guys once before - right the first time so trying again for a different problem. I've got a Frigidaire glass-top electric range (model PLEF398CCD) and 2 of the four burners stay on...
Thanks for using Fixya once again we appriciate it!
The problem with your stove is going to be with the infinate switch(what ya are calling knob) for the burners that giving ya trouble are shorted and the contacts inside of it are welded so they permanantly are stuck on the HIGH setting. To repair that the switches for the affected burners would need to be replaced.
The part number for those switches is 316095503 they could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 02, 2011 | Kitchen Ranges
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
Searing Unit Keeps Cutting Out After Release of Knob
First I have a couple of questions for your question on how to fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free: (800) 468-5252
Local: (972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Apr 10, 2010 | Brinkmann Stainless Steel All-In-One Gas...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Coleman Roadtrip Grill LXE 9949-750 Logo
4,557 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Treefrog15
Treefrog15
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
