When our fax enters sleep mode, we can't figure out how to wake it up to send a fax. Help! Please :-) I looked through the book, it just tells how to setup Sleep mode. Thanks!
I have the same problem. I didn't set any password. If one is set, how can I retreive/reset it?I have the same problem. I didn't set any password. If one is set, how can I retreive/reset it?
AnonymousMar 27, 2014
wont wake from sleep mode. will copy but wont printwont wake from sleep mode. will copy but wont print
You can't post conmments that contain an email address.
Th only way i have been able to get it out of sleep mode was to pull the plug and it resets.Th only way i have been able to get it out of sleep mode was to pull the plug and it resets.
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
Sleep Mode Setting the Sleep Mode reduces power consumption while the machine is idle. You can choose how long the machine is idle (from 00 to 99 minutes) before it drops into sleep mode. The timer automatically resets itself after the machine receives a fax or PC data, or makes a copy. The default setting is 5 minutes. 1 Press Menu, 1, 8. 2 Use the Dial pad to enter the length of time the machine is idle before it drops into sleep mode (00 to 99 minutes), and then press Set. 3 Press Stop/Exit.
Sleep Mode
You can choose how long the FAX/MFC is idle (from 00 to 99 minutes) before
receives a fax or PC data or makes a copy. The default setting is 0 minutes.
1 Press Menu/Set, 1, 7.
and then press Menu/Set.
3 Press Stop/Exit.
Press Menu/Set, 1, 6, 2.
2 Use the dial pad to enter the length of
time the machine is idle before it goes
into sleep mode (00 to 99).
Press Menu/Set.
3 Press Stop/Exit.
i don't have the owners manual handy, but i'm quite sure you can disable the sleep mode by pressing a couples of buttons on control panel. that procedure is in your owners manual on the same page as setting sleep time.
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long enough to insure that you will not always have to wait for the Brother machine to warm up.
