Question about Pentax *ist D Digital Camera
Remaining images counter problem on *ist D
I got an *ist D in February. In July it developed a problem with reading the memory card. I sent it back to Pentax (in the UK) and after a month or so it came back. It was able to read the memory card again and function normally except that the remaining images counter seems to be stuck on 999. I sent it back again to try and have this problem resolved but it has come back in exactly the same condition it would appear. The count of remaining images is still reading 999 on switching on and it remains on that figure regardless of how many images are taken. This occurs with both a 1G microdrive I got with the camera and a 1G compact flash card I got subsequently. I have tried reformatting the memory but it made no difference. I have been back on to Pentax who have asked me to return the camera yet again. However, before doing that and having to be deprived of the camera for possibly another month I thought I would just ask here if anyone has encountered this problem before and if, by any chance, there is a simple solution available.
    Master:
  • 542 Answers
I've had this problem... it was, of course, the quality setting which was reduced to lowest by whoever was doing the repair. I have never used this setting almost always using the *** setting or RAW. When I set these I get the kind of numbers I was used to in my remaining images counter. I am so glad I came on this forum and now the only fly in my ointment is the embarassment I feel for not having spotted the problem and the realisation that this may have been the problem before and I need not have sent my camera off on the second occasion.
Posted on Sep 08, 2005
SOURCE:
Minolta Dialta Copier Di152, code reads 32-COF
Replace the developer and developer unit. And Replace the drum normally done together make sure to reset the drum developer counters because the machine use the counters to set voltages to the drum and developer and it is the only way the copier knows it has a new drum and developer reset the counters without replacing the drum and developer causes code sand image problems
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 16, 2012 | Minolta Office Equipment & Supplies
Tip
If your camera will not read or transfer internal images on to memory card
When your camera will not transfer images onto memory card this is often because the image storage has been set to 'Auto'. You need to set it back to internal memory temporarily to allow you to copy the images over to the card. Once you have done this you can set the camera back to 'Auto' and this will reset the system and you will now have access to all of the images on the card.
This particular procedure works with all cameras but the steps outlined here are for Kodak in particular.
Please follow these steps;
1) Insert the card
2) Turn the camera to Auto
3) Press review - "reading memory card"
4) Press menu and scroll down to image storage and press ok
5) Select Internal Memory and press OK
6) Scroll down to Copy - Copy Pictures to memory card
7) Scroll down to ALL and press OK - you should see "Copying" displayed
8) When the screen goes back to the main menu - Scroll to Image storage again and select Auto - OK - "Reading memory card"
You should now be able to see the pictures from your internal memory saved onto your memory card and your camera is once again ready to use.
Hope this helps. Please do register your vote using the Yes/No buttons below to reflect the helpfulness of this Tip.
on Dec 22, 2009 | Cameras
Pentax IST DS & 2 GB SD cards
You need to upgrade the firmware on the camera. The latest versions will support cards bigger than 1GB; as delivered 1GB was the max.
Oct 24, 2008 | Pentax *ist DS Digital Camera
Nikon d80 frame count
264 is the minimum number of shots you can fit onto the memory card. A shot with large areas of black or white uses less memory than a more complex image and so the camera recalculates the number of shots remaining and so the number appears to go back up to it's original value.
Sep 10, 2008 | Nikon D80 Digital Camera with 18-135mm...
Downloading pics to memory card
a virus is present in your pc, infecting the memory card. I suggest that whenever your card leaves the camera and used in any computer or lab, always format the card in your camera not in pc cause this will gonna erase all the pictures including the virus. virus in cf cards wont destroy your camera but it will make it operates like crazy. Make it a standard operating procedure to always format card inside the camera.
Photolab will be able to read even a corrupted card.
Nov 09, 2007 | Canon PowerShot A520 Digital Camera
Why is my *ist DS eating my SD cards?!
I've used Sandisk Ultra II 512M cards, a PQI 1G and a Transcend 1G card (all high speed rated) in the *istDS. I've done about 1500 exposures now, many RAW, and have done several rounds of upload to my computer. No problems at all. These same cards work flawlessly in a Panasonic FZ10 as well. Either you have had a bit of bad luck, two defective SD cards in a row, or have a *istDS with a stuck or bad memory card controller. Try using the Reset command in the Set Up Menu, see if that helps. BTW, always format SD cards with the camera once before you start using them.
Sep 13, 2005 | Pentax *ist DS Digital Camera
What size of flash memory card do you recommend me using with my PENTAX digital camera?
The answer depends on your personal needs and your budget. Memory cards are available in many sizes 8MB, 16MB, 32MB, 64MB, 128MB, 256MB and 512MB. The larger the card size, the more storage space and the greater the cost. One recommendation is to select a card that allows you to take images without having to worry about changing cards or downloading images very often (one of the advantages of digital photography). Among the most popular are those in 64MB, 128MB or 256MB sizes. You may want to purchase a second card to use as a back-up or replacement card that can be used if you run out of space on the first card or to use when the first card is unavailable (you may be downloading or printing images from the first card.)
Aug 30, 2005 | Pentax *ist D Digital Camera
Pentax *ist D Digital Camera Logo
59 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
