How to remove an element from an economy 7 boiler. I tjought it unscrewed but I can't shift it
  • 639 Answers
Friend,
NGFAM! Happy to assist you!
Some economy jobs you can't remove them and have to replace them!
Get out the user manual or download it at the company web site or order it there! that could take time if you can't down load it!
Home Depot had a great sale on new ones this week too!!
Or if you have a plumber he can do the repair in 2 hours!
let me know how it worked out for you!!
Please give me a good rating here at fixya.com before you sign off!
Posted on Aug 29, 2008
I have a 9610 thermostat turns on and off to frequently
I am guessing but the thermostat is either faulty or is in conflict with another thermostatic device in the system. The room thermostat measures the air temperature in the room but with a modern intelligent boiler there will be other sensors measuring all sorts of things including the water temperature.
Personally I prefer to have thermostatic radiator valves rather than a room or zone thermostat.
Jan 02, 2017 | Heating & Cooling
70 series boiler model #70-148. I need the pionts/box that controls the thermosstat. It runs but it does not matter what the thermosstat is set at. I was told by a pro that the points are sticking. I
Be sure the thermocouple is still working, clean the contact points with crocus cloth and be sure the voltage going in to the controller is correct.
Jan 21, 2015 | Heating & Cooling
Johnson Starley boiler main board fuse blowing
Chances are the fuse on the circuit board is for control circuit protection. Take note of the location of all the thermostat connections on the circuit board and remove them. Do this with the power OFF. Replace the fuse and re establish power. If the fuse did not blow, the problem is in the wiring to or from the thermostat. It could even have the insulation rubbed through and making contact with the side of the boiler or a mouse could have chewed through the insulation causing a short to a metal object.
Once the issue with the thermostat wiring is resolved, reinstall the low voltage connections and you should be good to go.
Jan 08, 2015 | Heating & Cooling
What is a TPR valve on a Utica Boiler?
TPR Temperature and Pressure Relief valve. Usually mounted directly on the tank and has a lever on the valve.
Dec 27, 2014 | Heating & Cooling
How do I get my radiators to start working?
ch1 indicates wirless thermostats? check the thermostats in the room have fresh batteries. this type can be wired but may be running on batteries you have to use a screw driver from below to open the unit. if you dont have a manual here is a link.
http://www.manualslib.com/products/Danfoss-Randall-Tp5000-Si-Range-2781091.html
i hope this helped
Oct 22, 2014 | Heating & Cooling
How do I remove the "Keepers" from the media of an Ultra Cool CP70? I'm meeting resistance trying to remove them & am concerned that using force will break them. I don't know if they pop off under pressure...
I used a Mac Tools UT018 blind panel removal tool for auto upholstery panel removal. similar items may be found at your local auto parts store. I slipped the tool under the round washer up against the media and simply pulled. It removes the washer without damaging the locking pin or the media so everything can be reused. Simply blow out the media panel from the inside to clean any dust or pet hair from the media. Reinstall.
02c07c7d-c327-44c7-94fc-95e6951ead7e.jpg 72e80228-e907-4c58-8ead-f5717ed59225.jpg
Jul 20, 2014 | Heating & Cooling
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Nov 28, 2013 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
