Question about Maytag MER6772 Gemini Electric Kitchen Range
The cancel button stoped working
The cancel button for the top oven stopedworking after my warrenty was done
  • 3 more comments
  • dldavis Sep 14, 2008
    I have the same issue.
  • want2bsass Oct 13, 2008
    I have the same problem. You have to flip the breaker to cut the top oven off. I also get an error code of F1-7???
    I have the same issue I have to flip the breaker to cut my top oven off because the cancel button quit working. I also get the following error code F1-7?
  • amylinn Dec 04, 2008
    I'm having the same problem with the top oven. The bottom is working fine.
  • Anonymous Dec 14, 2008
    Same problem for us - Top oven only. Wife not happy with breaker solution... Anyone know about cost to replace / repair?
I have the same problem. I have to flip the breaker to cut off the top oven because the cancel button quit working. I get the following error code F1-7?
Posted on Oct 13, 2008
Purchased microwave Feb. 26,2015, stopped working last week. What can be done, it is still under warrenty?
Carman, quickly notify store and manufacturer for warranty usually one year I believe with receipt.
press the helpful button and follow me on fixya for more tips
Feb 09, 2016 | Cuisinart CMW-200 Convection/Microwave...
We have self cleaning oven and can't get door unlocked. It says "Press and Hold for 3 seconds"
Hello there:
if you have tried the 3 second option and it does not work here is what needs to be done
OK first something to remember
These ovens have a internal memory module that remembers every thng that it has done for a given amount of time and when this 3 second thing does not work this means that you need to clear the memory.
this is done by unplugging the oven from the wall or tripping the breaker
Now leave the oven sit for a minimum of 1 hour and do not touch
Now after the hour is up plug in the oven or set the breaker now you should hear a audiable beep within 5 min if so press the cancel button and your oven door will now open as it used to ok
and also if there is no beep that is ok just press the cancel button.
Hope this si very helpful for you .
Best regards Mike
Jan 22, 2011 | Ovens
My oven has been locked for almost two weeks. The serial number is: VF10409280 Item number is: 7909651001 The stove top works fine but I can not use the oven. I have unpluged it for 48 hours. pushed...
Hello there
This is a fairly common issue with these ovens
Any way here is what needs to be done and why
these ovens have a internal memory module that rembers every thing that the oven has done for a given time and in order to have the door unlock it needs to be cleared
So knowing this what you ahve to do is to unplug the oven from the wall and leave it unplugged for a minimum of 1 hour with out touching it then plug it back in and with in 5 min you may hear a click sound if so press the cancel button and then you should be able to open the door and continue from here ok
So please try this and tell me how this is working and i will help you if there is still a issue with this
ok? best regards mike
Dec 07, 2010 | Kenmore Ovens
Dacor Preference range oven stoped working
You can try turning the breaker off to the unit for 10 minutes or so but if that does not work you will need a new control board to fix it. they usally range from 100-200 dollars.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Dacor Preference RSE30SS Electric Kitchen...
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Electric oven
was there a lightening storm (that may have zapped the micro-controller chip) prior to the problem?
May 06, 2007 | Maytag MEW5530D Electric Single Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
195 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
