Question about Refrigerators
Its a frost free freezer the problem is the plug had came away from the socket for 24 hours without knowing when we pluged it back in it will know longer freeze
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
The fact that it was left off and then restarted is coincidence, to the failure to work! There was already a problem that was waiting to happen, without any ones help!
So do not blame the person who caused the freezer to be unplugged! freezers with a lot of food in them can stay frozen more than 24 hours if no one keeps opening it! Even 48 hours!!!
Time for factory service and diagnoses!
If the freezer is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and save you real money on your electric bill!!!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
We have just moved a freezer and pluged it in but it doesnt turn on. it is pluged into an outlet with power i tested that
The Danby freezer(DUF808WE) doesn't work from yesterday, even proper plugged in?
I already check electrical outlet. How can I fix it?
Jul 08, 2011 | Danby Freezers
The "de" is flashing on my display. I know it
Try the reset procedure:--- Turn the fridge freezer off by the wall socket for 10 minutes. Then reconnect the power again and see.If that is not helping then ,DE is most likely indicating a defrost problem.. open the freezer and take a look at the back of the freezer wall - is there a bunch of frost on that back wall? If the ice is collected there then unplug the unit for 24 hours to manually defrost it or take a hair dryer and defrost all collected ice to defrost the ice quickly.There also could be a temperature problem due to a defrost failure, easy to check the freezer temperature to confirm.---------------- Thank you.
Jan 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Motor still running after gasket replacement
it will take at least 24 hours for the freezer to settle down to the correct temp -18c.the water is the frozen condensate that builds up inside the outer door over a period of time and should be allowed to drain away when you do a full 48hour defrost once a year....frost free means frost free where there is an air flow.....
Jul 21, 2010 | Amana ABB1927DE Bottom Freezer...
I NEED TO KNOW QUICKEST WAY TO DEFROST AND WHEN RUNNING NORMALLY
the SAFEST way to defrost your refrigerator, is to unplug, open both doors, and blow a fan for 24 hours. Doing anything other than this, in order to "speed it up" can cause SERIOUS damage to the unit.
Keep in mind, this is ONLY a temporary fix, unless you fix your defrost problem, you will have to do this again in 7-10 days, repeatedly
Apr 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Kenmore Elite ice maker doesn't work
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting.
If it still exists then there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Sep 25, 2009 | Kenmore Refrigerators
Subzero freezer drawer left partially open- went into shutdown. This has happened before, and there was a trick- like turn the freezer control to 1 for twenty-four hours, then up to 3 for twenty-four...
unit is most likely frosted over. bets thing to do is turn control for freezer to off for 24 hours, put down some towels for the water and prop the drawer open at least 6 inches. Then turn back to normal setting and allow 12 hours minimum for normal tenperature
Jul 17, 2009 | Sub-Zero 650 / O Bottom Freezer...
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Fridge freezer noise problem
Yes...The same thing happens to me. It's coming from the back of the freezer and it's where ice gets clogged around the blades. The best thing to do is turn it off and defrost it. Even though there's no ice inside the freezer, being frost free, this will sort your problem i'm sure....
Sep 30, 2008 | Hotpoint HSS25GFP Side by Side...
Water leak
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
Aug 23, 2008 | Freezers
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
