Question about Pentax AF-360 FGZ TTL Flash
Problem with AF-360FGZ Flash
Just some questions about this flash (using on a *istD). 1. Why it needs so long time to recharg? Everytime after the flash fires, it needs several seconds to charge before it can fire again. I'm using Sanyo 2300ma rechargeable AA batteries and all flesh-charged. Cannot use continues shoot w/flash :( 2. Set to high-syn flash is the only way I can get speed high than 1/150, no matter what lens I use. Is this right?
    Master:
  • 542 Answers
I use 2500 rechargeables and it is ready to fire almost instantly. Are you trying to light up a big area and therefore using full discharge with each fire? Maybe this is why, but I don't know as I have never had the problem. I am quite surprised by how quickly my AF360FGZ is ready to fire again.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
Yes. The *istD shutter can only provide X-sync for electronic flash up to 1/150 sec. The *istDS reaches 1/180 sec. "High speed" electronic flash is done by strobing the flash repeatedly during the period that the shutter slit is traveling across the focal plane, at th expense of cutting power output quite a bit.
How to set metz 50 AF-1 flash off camera TTL to Nikon D800
There are many solutions, here is an example:
http://www.pocketwizard.com/products/cable_accessory/flash_sync_cables/
Mar 27, 2014 | Metz Cameras
Nissin di866 overheat problem
Are you using rechargeable batteries or alkaline ?
Apr 07, 2017 | Nikon 18-105mm f/3.5-5.6 AF-S DX VR ED...
Manual af-360fgz
You may download the manual here.
Dec 11, 2011 | Pentax AF-360 FGZ TTL Flash
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Exposure problem
I've found that the *istD underexposes ( as it should metering 18% grey ) light subjects, or with light backgrounds. A white wall using TTL ( AF500ftz ) behind any subject it always turns grey! You need to manually adjust 1 stop over. With dark subjects, overexposing with out blowing out much. If your used to the metering from a PS digi cam the *istD takes a bit of getting used to.
Sep 08, 2005 | Pentax *ist D Digital Camera
Pentax AF-360 FGZ TTL Flash Logo
266 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
