Question about Refrigerators
Amana Refrigerator Not working. One repair guy said it is the low volt pc board; which is no longer in production. He is not 100% sure, but cant think of anything else. Other guy said it is the compressor which is leaking coolant and has low flow. Symptoms: lost cooling capacity, freezer completely defrosted, bottom back of freezer was iced over, alarm was sounding off.
  • 1 more comment
  • daliablass Aug 28, 2008
    Unit is 7 years old and it is an built-in...not cheap or easy to replace.
  • gspell1958 Oct 28, 2008
    You answered my question with this post. I really appreciate it and so does the elderly lady with the 8 year old Amana. You helped me convince her it was more worhtwhile to purchace a more energy efficient unit instead of throwing good money after bad with the old one.
    Thanks,
    George W. Spell
  • Anonymous Jan 09, 2009
    not cooling, freezer is completely defrosted and upper section not cooling.
Thanks,
George W. Spell
Posted on Oct 28, 2008
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
How old is the fridge ?
If its 10 years old its not worth repairing!
You will save enough money with a new fridge due to the fact that they are so much more efficient today!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
I have an Amana refrigerator door light switch part# C8967502 that is no longer being made. Is there another mfg. who makes a switch that could replace the original Amana switch Thank you Denis Subler
I'd think that any of the local appliance repair shops would have an old stock of those replacement switches. Sure, maybe Amana doesn't have them, they dump old stock, but they dump them to repair shops!
In any case, any "normally open" switch can be retrofitted, even in-frame burglar alarm contacts can be used for that application. The switch when pressed IN is open, not letting power come to the bulb. When the door opens, the switch pops out and "closes" the circuit to let power to the bulb.
You may even find on available to retrofit, at Radio Shack.
Feb 03, 2011 | Maytag Refrigerator Door Light Switch...
Tip
Caution : Your Technician
If you have used the same technician for a while , and you are confident he will not " gouge " you , you are in great shape . However , finding a technician in this category , is extremely difficult .
For example : A tech comes to your house , and tells you " you have a freon leak and it should be recharged " . He puts a little ( maybe ) freon in , and charges you hundreds of dollars . First off , it is extremely ( ! ) rare , for a 2- any age refrigerator , to be low on freon ( except Amana , which is known for its' leak at the evaporator , where the copper connects to the aluminum coil ) . A while later , it still does not cool correctly , so you call him back . He comes back and says " OK , you now have a ** problem and it should be repaired , and you are still out the hundreds you paid previously .
I have yet to come across a refrig , from the factory , to be low on refrigerant ! I have found access valves , where a " tech " adjusted the refrigerant , still on the refrig , leaking . A good tech ALWAYS removes the access valve when finishing his/her work ! This avoids the possibility of a leak . If a refrigerator is low on refrigerant , it will stop cooling within the first year , which is a warranty repair . Not 5 - 10 years later ! Except Amana . Factories do not want their product to have problems , so , they do keep a close eye on the quality of their product ( such as leak testing , soldering quality , cosmetic looks , and any other issues demanded by the manufacturer , such as GE , whirlpool , Maytag , etc . ( not Amana ) .
Another problem , is the refrigerator control boards . Same thing . A tech , not familiar with the operation of the electronics , may tell you , you have a bad board , when he doesn't know how to check ( only that the control boards go out sometimes ) . He gets your money and a week later , same problem ! You do not get back the money you paid ( ! ) only maybe charged a slightly lower cost for repair ( different tech from same company who might be a little more knowledgeable on your product ) .
Another example is range control boards . Same situation . Replace board , pay lots of money , days later same problem , different tech finds different problem , pay a little more money .
A GOOD tech , will tell you " I am not familiar with this product " . He is the one you should try to keep , as what he is good at will be a substantial benefit to you . A bad tech , will just dig into the product , without knowing or being familiar with the operation , parts used , and their operation .
Be back later , to add or edit .
on Apr 23, 2010 | Refrigerators
Cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
May 03, 2010 | Dometic NDR 1292 Refrigerator
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My side by side Amana water dispenser no longer
you have a kink in your tubing test by checking at pump which is visable by taking back felt cover at bottom where water tube goes in cut a few inches away from pump to see if water flows when you activate swich if so you have a kink in your system to repair the cut they have couplings in the store
Mar 22, 2010 | Amana Refrigerators
It doesen't put out 120 volts continueslly. It'll
you can search in the local repair section of fixya for a repair shop,for you problem,are you sure your batteries are still in good working condition i.e reading 12volts when battery is low
Feb 25, 2010 | Schumacher 1000 Watt Inverter with 2 GA....
The sensory board has gone out three times and the stove is 5 years old
I don't think the boards are your problem / look for power problem like low voltage / voltage surges / -- because this is 120 volts you could use a suruge control at the plug .. don't use a cheap one .. board arn't cheap .. make sure the electrical gorund is a good on.. poor grounds cause other problems in th house ..ck it good. **** ..
Dec 04, 2009 | Amana AGDS902SS Gas Kitchen Range
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Nov 04, 2008 | Amana D530M Dehumidifier
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
