No indicators working found fuse box which fuse?
When you are talking about "indicators" we could assuming that your are refer about signal lights. This work with "flashers" devices.
For 1996 Audi A4 2.8L SFI 6cyl the Flasher is located in front seating area, driver side, under dash, behind dash lower panel, mounted above driver side of steering column.
About generic fuses, open the driver side door. Remove panel on left side of dash. Fuse box is behind panel:
Fuse # / Description / Amps
1 / Heated washer jets / 5
2 / Turn signals flasher unit / 10
3 / Headlight washer, illumination of glove compartment, engine
compartment, climate control, automatic transmission, instrument cluster
/ 5
4 / License plate light / 5
5 / Instrument cluster, seat heating, test connection for cruise
control, bulb monitor for auto-check control, Automatic transmission
display, switch lighting, mirror switches and actuators, airbag warning
light, outside temperature indicator, Climate control / 10
6 / Central locking system / 5
7 / Anti-lock brake system / 10
8 / Vacant
9 / Mirror heating / 10
10 / Vacant
11 / Cruise control (automatic transmission) / 5
12 / On board diagnostic system / 10
13 / Brake lights / 10
14 / Interior lights, reading lights, anti-theft alarm system, vanity
mirror / 10
15 / Instrument cluster, power windows, climate control, automatic
transmission / 10
16 / Anti-lock brake system, Anti-Slip-Regulation / 5
17 / Heated door locks / 10
18 / High beam right / 10
19 / High beam left / 10
20 / Low beam right / 15
21 / Low beam left / 15
22 / Tail and side marker right / 5
23 / Tail and side marker left / 5
24 / Wiper and washer system / 25
25 / Blower for heating, climate control / 30
26 / Rear window defogger, mirror heating / 30
27 / Rear window wiper / 15
28 / Fuel pump / 15
29 / Engine timing / 20
30 / Sun roof / 20
31 / Tail lights, cruise control, automatic transmission / 15
32 / Engine timing / 20
33 / Cigarette lighter / 15
34 / Engine timing / 15
35 / Trailer receptacle / 30
36 / Fog lights / 15
37 / Radio / 20
38 / Luggage compartment light, central locking system / 15
39 / Emergency flasher / 15
40 / Horn / 25
41 / Anti-lock brake system / 25
42 / Vacant
43 / Vacant
44 / Seat heating / 30
Hope this helps (remember to rate and comme this free answeer).
the dash lights are not working
