Question about Intel Motherboard
Increasing Memory Ram
I have a MSI Motherboard MS-6390, an AMD Athlon XP 2000+ 1.67 GHz and 128 MB DDR PC2700. I want to increase the memory RAM but I have a doudt
this motherboard can support a memory ram PC 3200 (DDR 400)?
I would appreciate your help. Thanks.
  • ingmore Aug 31, 2008
    Thanks a lot. The information you provide was very helpful.
    Brigadier General:
  • 5,158 Answers
Main Memory • Support four memory banks using two 184-pin DDR DIMM. • Support a maximum memory size of 2 GB • Support 2.5v DDR SDRAM DIMM. an excerpt from the manual
Hope that helps
Posted on Aug 28, 2008
  • 5,568 Answers
Check this page, I think it will answer your questions:
http://www.crucial.com/eu/store/listparts.aspx?model=MS-6390
    Master:
  • 397 Answers
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
3 Suggested Answers
  • 35 Answers
SOURCE: RAM Capacity of Motherboard MS 6166
I have found a manual for your motherboard. The board can support up to 256MB of RAM. The manual will tell you all of the specs you will need to know. http://www.motherboards.org/mobot/manuals/MSI/MS-6166/ Hope this helps. Good luck.
Posted on Jun 27, 2007
mithunsree
  • 32 Answers
SOURCE: Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Posted on Aug 11, 2009
Abit NF7-s - hynix ram support problem
The problem probably is you mixing fsb speed, all the cards should
be pc3200 or all of them should be pc2700.
You don't mix.
Feb 13, 2010 | Computers & Internet
How mutch RAM does "Motherboard MSI PM8M3-V (MS-7211 v1.x) Micro-ATX" supports
Spec sheet shows you can run 2GB of PC2700 DDR RAM (DDR-333), or PC3200 DDR RAM (DDR-400); http://www.superwarehouse.com/MSI_PM8M3-V_Micro_ATX_Pentium_4_Motherboard/PM8M3-V/ps/727805
MSI also provides a list of tested memory for the board;
http://www.msi.com/uploads/test_report/TR10_234.pdf
Hope you find this helpful!
Mike
Oct 12, 2009 | MSI PM8M3-V Motherboard
Aug 11, 2009 | Intel D845GVSR Motherboard
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Why won't MB recognise new 2 x 1Gb Memory?
The motherboard does not support 1 GB modules; 512 MB is the maximum the motherboard will recognize. Usually, the computer won't even work if the memory isn't supported but in this case it does.
Thanks and please remember to give this a thumbs up rating.
Apr 26, 2009 | MSI MS-6390 (-6390-010) Motherboard
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Memory +cpu upgrade
No to the cpu you selected. Board would not support that cpu. The RAM you selected would probably work but for how long I couldn't say. With prices pretty low right now it would probably be better to purchase a new motherboard, cpu, & RAM. Hope this helps.
Jan 10, 2009 | MSI MS-6367 Athlon XP 266FSB MicroATX...
Memory dump.
It dumps coz you havent enough of memoy, instal at least 512MB more and you will get rid of that problem
Good luck to you
Dec 30, 2008 | MSI KT2 Combo-L Motherboard
Motherboard makes several loud beeps when turned on
Is the memory the right type? It sounds like the board isn't sensing any memory. HP do often use boards that have particular memory dedicated to them. Should be DDR RAM pc3200 (unbuffered, and you can have up to 2048mb Ram Max. (2 Slots)
Dec 31, 2006 | MSI MS-6390 (-6390-010) Motherboard
Intel Motherboard Logo
131 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
