Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
How to secure my wireless
Tell me the procedure how to secure my modem wireless to protect from others
  • Anonymous Sep 02, 2008
    made it secure but wont allow other computers access
    Sergeant:
  • 359 Answers
Click on Start Button
Goto Run
Type in cmd
Click OK
At prompt type ipconfig
write down what your gateway IP is
Open up Internet Explorer and type in gateway IP addy in the address bar
Goto Wireless security section and away you go...
Posted on Aug 28, 2008
I wanna protect my connection from outside users i dont know how to protect it !! please help me out!
You listed your problem ubder: modems. A modem you do not need to protect further. You can only use the connection by hooking up a cable to it. If you have a wireless router connected to your modem that should be secured. You do this by entering a security code in the setup of the router. just enter the router's IP address in your web browser, log in to it,go to the security tab under wireless setup and enter a security code. (write it down because you will need it to connect wireless). You can not connect to it without this code. This way your wireless connection is secured and can not be used by outsiders.
Feb 10, 2011 | Computers & Internet
Our wireless is not password protected. How can I set it up to be password protected so other people cannot access our wireless.
You can secure your wireless network by following the step by step procedure from this link , this is a link to my TIPS just click HERE and follow the procedure there.
Jan 28, 2011 | Linksys Wireless-G WRT54GS Router...
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Jan 02, 2011 | Video Game Consoles & Games
When i connect i get this message' your wpa key you entered may not be correct"
Jan 01, 2011 | Sony PlayStation Portable (PSP) Console
My neighbor is connecting to my router,Iwould like to stop him
For wireless security:
You need to login to your modem and add security, so that you can connect and your neighbour cannot. Unless you have changed your login details, look at the back or underneath your modem. It should tell you what your defualt login is and how to get to it. You normally access your modem using a web browser (Internet Explorer, Chrome, Firefox etc.) and typing in the address e.g. 192.158.0.1 in the top/address line.
Then you will be prompted for a username and password (see what the sticker on the modem says, e.g. admin and password.
Once inside that menu, look for WLAN or Wireless settings. You can then setup security e.g. WEP or WPA and some other options. Set the security to WPA and choose a password that you can remember. Once you have chosen Done/Apply/OK or similar, you will probably lose your connection. If you then choose your wireless, you will be prompted to enter a password.
The other alternative is, if you have a desktop connected by ethernet to the modem and don't need wireless, you can go into the same menu and switch wireless off.
Sep 29, 2010 | D-Link DIR-625 (790069292637) Wireless...
I pushed the reset button on my router and now I have no protection from others with my wireless, how can i protect that?
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys Wireless-G Broadband Router
Got a linksys wireless-G 2.4 ghz broadband router and all i have is the router and /ac pwer cord..can you tell me what other cables/cords I will need to set up and basic set procedures..Thanks
You will need a Cat 5 or 6 ether net cable to connect yout wireless to the cable modem.
If you want to connect with wire to this rouger from other devices, you will need additional pieces of cat 5 cable of appropariate length.
Be mindful that wire is secure and operates at 100. Wireless operates at 10. Wireless range is about 300 feet radius.
I hope this helps you.
If you have concerns or questions, post a comment to this quesiton
thanks for using FixYa.com
PLEASE vote
thanks
a
Dec 15, 2009 | Linksys Wireless-G WRT54G Router
MAKING A WIFI MODEM SECURE
Change the "settings password" from default password to a complex one. Next make sure u set the wireless security to WPA or WPA 2 and password protect it too. (to go to settings of your modem type 192.168.1.1 in internet explorer)
Mar 18, 2009 | Computers & Internet
Security password
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
Go there and download the manual, its easy to setup a password, just follow the instructions on the manual.
Good luck
Dec 04, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
