Question about Toshiba e800 Pocket PC
Toshiba e800 perform hard reset after changing battery
Sometimes when I change the battery of my Toshiba e800 there results a hard reset. May be the backup battery did not work? How can I check this?
    Master:
  • 903 Answers
At first you should assure that the backup battery is definitely charged. I suggest to charge the PDA a hole day without using.
Posted on Sep 08, 2005
SOURCE:
Problem serial connection e400 using cradle
I am not 100% sure if I am correct in this, but I am quite sure that the e400 does not support a serial connection. Only the e800 does.
Sep 11, 2005 | Toshiba e400 Pocket PC
Tip
HARD RESET Toshiba e310 e330 e335 e350 e355 e400 e405 e570 e740 e750 ...
Make sure your device is off before performing hard reset. While holding the power button press in on the reset switch with your stylus then release the power button. When a screen appears release the reset switch.
on Mar 10, 2010 | Cell Phones
Screen light defect?
I had a similar problem after removing battery on my e800. After battery full charging and after PDA resetting everything was OK again.
Sep 11, 2005 | Toshiba e330 Pocket PC
E800 spontaneously resets
this hard reset is based on a slack joint. You could test it, if you turn your PocketPC on, and tip on the cover, near the Display or the Battery. If the PDA make a reset, your Pocket PC need a repair.
Sep 08, 2005 | Toshiba e800 Pocket PC
INTERNET EXPLORER
I have the same PDA but unfortunately I am not the expert. In my opinion it is not possible to install IE separately. It is not known to me that there is any possibility to download IE for PDA as an individual program. If you have already removed all programs why don’t reinstall the OS and it should work properly again. Did you already install Windows Mobile 2003 SE? Please go to www.microsoft.com and download iExplorer! Try to install it!
Screen Lock up
If I understand you right there is problem with Touch screen because, I suppose, a mylar is not attached correctly to the Top Case Assy. This causes a permanent pressure on the screen. I am not sure but there should be changed the top case mylar. In my opinion you should contact Service Partner in your country and ask them what the best way to solve this problem is.
Problems with e800bt
I don't know much about italian warranty conditions bt in Germay you can ask to change the PDA after it is repaired three times without success! I think it is the best to contact Toshiba Italy directly and tell them your story and ask what to do! TOSHIBA EUROPE GMBH - Sede Secondaria in Italia CENTRO DIREZIONALE COLLEONI Palazzo Perseo - Via Paracelso, 10 20041 AGRATE BRIANZA (MI) Tel. 00 +39 (0)39 68730.1 Tel. 00 +39 (0)39 68730373 Telefax 00 +39 (0)39 68730369
Hard reset after changing battery e800
Like you know if the PDA is without power supply more than 72 hours there is risk of losing data. In my opinion you should be careful about that and data saving is very important. Till now I had no experience with changing battery and I can not give you a precise advice about that.
E800 with bluetooth card 2
It is very strange. The only thing that I can recommend you is to check Toshiba Bluetooth download page and check for stack update or FAQ page. Check it on http://aps.toshiba-tro.de/bluetooth/
Toshiba e800 Pocket PC Logo
252 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
