Question about GE Tritonr XL GSD6260JCC Dishwasher
GE Triton XL
We have been using the detergent packets for a few years now in our GE Triton XL dishwasher and had no problems at all. However, in the last couple of weeks, it is as if the door to the detergent compartment is not opening during the wash cycle. Instead of releasing the detergent, the packet is melting. We also tried liquid detergent with the same results. At the end of the heated dry, the detergent was still in the compartment. My detergent packs are sitting in the bottom of my dishwasher after it finishes running. Looks just like it did when I put it in the dispenser.
  • 706 Answers
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Posted on Aug 29, 2008
How is the china and crystal wash cycle different from the regular cycle on my GE Triton XL dishwasher? Can I use regular dishwasher soap on my china and crystal?
Most dishwashers that employ this setting use a lower temperature for the water and also they do not use the element to dry the dishes, they are air dried. China and crystal are very sensitive to changes in temperature and can crack easily. They should always be washed by hand however if you have to use the dishwasher make sure you have a mild detergent. No bleach or acid should be contained. If it says citrus anything it has acid in it. Also use half the amount of detergent regardless of its strength. Hope this helps. Good Luck!
Jul 19, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
My triton xl, will not get water in. If I put water in the bottom and turn on the water will clean the inside of dishwasher but if I start by itself no water will come in. I cleaned the inside it was...
First check that the water is turned on, usually found under the sink. Next check the float located inside the front of the tub. When you move it up and down it should click. Remove and clean around the tube.(It may need to be disconnected through the lower access panel. The screen on the water intake valve may need to be cleaned-also located behind the bottom front panel. If this doesn't fix the problem you may l need to replace the water intake valve or pressure switch.
Sep 18, 2010 | GE Dishwashers
My GE Triton XLdishwasher, model GSD6300 Gooww is leaving a
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Eric
Dec 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE Triton XL, Dishwasher, while washing dishes in the sink
Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
Jan 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE TRITON XL REPLACEMENT SOAP DISPENSER?
Best way is to call GE Part at 1-800-626-2002 or go online to www.geappliances.com
Dec 20, 2008 | Dishwashers
GE Triton XL Dishwasher
Make sure wash arms are going around. Set the arms to point right at you and mark with a marker (so you can tell if the arms moved, not just turned 180 degrees) and run the unit for a few seconds. If the spray arms don't move, look for obstucted holes in the spray arm(s). Toothpicks, plastic candy wrapers, seeds, etc. If all clear, so an "Ask Me" for other ideas.
Sep 02, 2008 | Dishwashers
My Triton XL soap dispenser still has a clump of soap after the cycle has finished. My glasses are left with a cloudy film, and my silverware is left marked with film on it. I have cut down on the amount of detergent, and have not overfilled. I have also tried using white vinegar as the manual states. Any suggestions? Thank you
Aug 17, 2008 | Dishwashers
It's normal for a little water not to drain. However, many times it's that the drain hose isn't looped up high enough under the sink and water is draining back from the sink or disposer drain- into the dishwasher. If there's a disposer, be sure to run it once in a while, a good time is when the dishwasher drains. The hot water and detergent keep the unit clean, and draining correctly.
Oct 24, 2017 | GE Tritonr XL GSD6260JCC Dishwasher
GE Tritonr XL GSD6260JCC Dishwasher Logo
741 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
