Goto Start, Control Panel, add or remove programs.
Uninstall the sound card drivers.
Reload the Sound card drivers from your Setup CD.
Every thing should work fine then.
When you load SP3 some of the drivers get corrupted (lost).
Dear the drivers which u have for vista for eg LAN / SOUND/ CHIPSET they all are common for any operating system ur load...............so don't take tension install xp & load the drivers.........................Sameeraryan
Hi there. It sounds like the XP you have installed doesn't have the correct/updated driver for your sound card. Try installing the most current Sound driver from the manufacturer's website. It would also be a very good idea to download XP Service Pack 3 from Microsoft, as this will have added support and drivers in the database.
change from windows to xp,but sound driver was not loaded/installed so there is no audio sound in my pc.from where n what driver to install in window xp for free.kindly advice n thanks.
If your drivers are from trusted source just click ok continue when the windows signing for drivers pop up window appear.
Now if you click ok and then the system fails to load and then give you a blue error screen, its caused by either
The hardware or its drivers cause conkflict to the system, because your drivers are not from a source you can trust and they are not in compliance with windows OS features and as a result can not run in a windows OS. So get a fresh copy of the drivers from a trusted source preferably the product manufacturer
The hardware itself is faulty and on installing to XP it causes a conflict in which case you can try the Sound card on a different PC and see if it runs, otherwise you need to replace it.
(Assuming XP has finished loading the OS) Sometimes XP fails to unistall the previous drivers, if this is that case goto the device manager (windows icon >right click > properties >hardware > device manager) select ypur current sound card unistall the driver that is there and then restart your machine and load the new drivers again
