Question about HP iPAQ H4150 Pocket PC
IPAQ 4150 & WiFi
I configured WiFi to connect to my work network that additionally use Odissey. The problem is that when I enabled Wireless, I wasn't able to Power On or Power Off my iPaq. It stays Powered On and when the display shut down, there is no way to recover it, I have to hard reset it to have the screen back again. I tried to disable wireless, but it wasn't possible through the application. I'll appreciate if somebody had seen that and help me
    Master:
  • 450 Answers
Hi i've never known them not come back on after going off, but have noticed they do switch back on, on their own when the wifi is enabled. when i want mine to stay off i tap the arrows at the top of the screen and select "turn on flight mode" this will then stop the device searching for a network and will shut down. when you want wifi again turn the flight mode of in the same way.
Posted on Sep 08, 2005
My asus will not detect a wireless connection
Hello
check if the led is turned on,if the lead is turned on make sure that the network card is not disabled . check it under network connections and see if it is disabled, enable it.
what does it say when you are trying to scan for the wirless netwroks..
it should either say A) No wireless were detected in the range ... if you get this message it means that you wifi is working fine on the laptop .. check if you can see the wifi turned on the router .
Windows is not configured for this device( or something like that ) .. if you get such kind of message it means you have not enabled WZC(wirelesss zero configuratioin).. for that click on start -- Right Click on MyComputer -- Manage -- Services -- Find wireless zero configuration -- enable.. (After this go to network connstion -- Rightclick -- Propterties--Wireless networks -- Check the box that say use Windows to configure the device.
Apr 12, 2011 | ASUS L8400-C Configurator (ASNB100) PC...
When I try to connect using Wireless Network connection the following error message now appears: "Windows cannot configure this wireless connection. If you have enabled another programme to manage this...
Your obviously having a network configuration issue. Go into Network icon, set up a network connection, make sure you have Wi-Fi and that your laptop is picking up the signal then manually set up or scan for the wifi access point, your laptop should pick up the access point and a name should appear for that wifi spot. Once that is done then you can rename your access point with your name or HOME whatever you like, its hard to explain through here.
Jun 13, 2010 | Acer Ferrari 4005WLMi Notebook
I can't seem to get the wifi to work other then when I'm at home when I don't need it how do I get it to work. Please be simple in your answers not too tech savvy but I love this thing already, and have to...
You have configure the wireless connection at that place where you want to get connected. Like you have done at home.
Most of the wireless connection are secure and cannot be accessed.
Thanks
Smith
Sep 11, 2009 | HP iPAQ HX2490 Pocket PC
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
I m havin BSNL ADSL2+ DNA-A211-1 modem..i don know how to connect my laptop wit modem in wifi mode..pls tell how to configure n connect it..modem has ethernet port oly not having usb port..pls suggest some...
Secured Wireless is better than a unsecured one. Configuring a secured wireless network easy.
· First Check it the Wireless is turned on in the modem.
You must see the wireless light glow on.
Wireless LAN (WLAN) should be Enabled before configuring the wireless network
· To make sure, if the WLAN is enabled you can check the WLAN light glow.
· If it is off, then you can be sure that WLAN is disabled.
May 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
IPAQ 4150 won't show any web pages even though it's connected.
I fixed it! Instead of selecting "connect to all available networks," I selected "connect to selected access points."
Dec 30, 2008 | Orange SPV M1000
HOW TO CONFIGURE WIFI WITH Compaq Model C765TU in XP
Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 29, 2008 | Compaq Presario 700 470024-192 Notebook
TRYING TO CONNECT WIRELESSLY TO THE INTERNET DOESNT WORK
wow! thats a very nice wifi card. prism.
anyway, here is a link for your windows 2000.
this connects you to any wifi hotspot other than boingo.
cheers
Mar 27, 2008 | Fujitsu LifeBook P1120 Tablet PC
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
HP iPAQ hx4700 Pocket PC
if your PCs connect wireleslly, then I assume you have set up a home network with a router/modem. Sometimes the modem comes combined with a router. If this is the case, then the 4700 has all you need to connect it to this network and access your emails and internet. This is an example of my setup with my 4700... Go to Start > Settings > Connections > Connections > click on Advanced tab at the bottom click on "Select Networks" button Both entries on this page should be set to "My Work Network". Click "OK" > "OK" back to Settings screen. Go back to Today Screen. Now click on the iPaq Wireless icon at bottom right of this screen. If the WiFi button has an 'x' on it then click it to turn it on. A blue light should now come on at the top of your ipaq to indicate that wifi is on. Click on the 'Settings' button You should be able to see your network on this screen - "Configure Wireless Networks" Networks to access should be set to "All Available" Check the box to 'Automatically connect to non-preferred networks' If the Network is available but not connected, then click on it's name. On this next screen you should select next to 'Connects to' - "The Internet" Then click OK If the Network shows 'Available' and not 'Connected' then click and hold on the name of the network and then you can choose 'Connect' Then under 'Network Adapters', on that screen it should say ... My Network card connects to 'Work"
Sep 07, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ H4150 Pocket PC Logo
174 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
