Question about Samsung Televison & Video
I have a Samsung B/W Monitor, model Name SSC-12M for an observation System. Turns on for a few secomds, and then gets a straight line across and turns monitor on and off, Capasitor maybe? Worth repair ing or replace, please advise
  • 4,234 Answers
The vertical Ic either has bad connections or is defective. Look for a small flat IC attached to a heat sink with about 11 pins. Try resoldering the pins first. If that fails to resolve it, replace the IC. This IC may be marked LA7837 or something similar. If you are unsure, post the marking here and I'll confirm you have the correct part.
Dan
Posted on Aug 28, 2008
Complete service manual for Samsung B/W Observation Monitor SSC-12M AC120V, 60 Hz, 38 W. The green front panel power lamp flashes and the machine emits a clicking sound. I have checked connectivity to...
Unfortunately, the devices aren't listed as the "set" - can you reply with the exact model number from the main unit?
If i cannot obtain the schematics after hearing from you... I will contact Customer Service to initiate a refund or switch to another expert.
Thanks!
Sep 28, 2011 | Samsung Weather Resistant Security Camera...
My SyncMaster 2233 has problem, it has two straight lines, one blue, one pink, across the screen, from top to the bottom. I'd like to know how to get rid of it.
If the lines are very thin, they are broken pixels. You have to replace the monitor. I've heard of people taking their finger and trying to rub the lines out, but I have never had success with this before.
Sep 13, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
We purchased a home with 4 samsung cameras in various places around the exterior. They are all wired back to the master bedroom with what looks to be CAt-5 cable. What do I need to make this system work??...
Hi there, depend on the model of your cameras, normally if there are samsung it should say the model # ( ssc-12c,soc-c120 and so on) What look like CAT-5 are normally RJ-11 very similar to a phone connector. If your cameras are one those mentioned above you will need a monitor that support that type of connection like the ssc12m or ssc-17webm if there are black and white or the SMT-190M if there are color cameras. or a DVR with similar connection type like the SHR-1041.
Thank You,
nationalprosecurity.com
Oct 17, 2010 | Samsung Weather Resistant Security Camera...
Looking to buy a moniter
I have two monitors.
I don't use them, because I used and adapted the cameras in another cctv system.
You can see a picture of them here
http://www.palleyd.com/ssc-12m-monitor.html
Jan 19, 2009 | Samsung Weather Resistant Security Camera...
There is lot of disturbance on the screen
Control Panel
Display (or Display Properties)
Settings tab
Advanced
Monitor tab
under Screen refresh rate, change to 70 hertz or higher
Apply, black screen
(Your desktop has been reconfigured. Do you want to keep these settings?) Yes
OK
OK
Nov 03, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
No picture
The green connectors are for PIR (passive infrared ) motion sensors to be connected, they have nothing to do with you recieving a signal from your cameras. Double check to make sure the camera jacks are securely connected on both ends (camera & monitor) , and then hit your AUTO button which should automatically cycle through your cameras if you are indeed getting a signal. If you arent, you have other issues. As to the monitor getting darker. You will need to adjust the brightness from day to night unless you have an alternate light source or IR(infrared) Illuminator for night viewing.
Feb 20, 2008 | Samsung Weather Resistant Security Camera...
Ssc-12c samsung b/w camera.
im trying to get the wiring dirgam for a ssc-12c camera
Dec 29, 2007 | Samsung Weather Resistant Security Camera...
Samsung B/W Observation System - Model# SSC-12
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Oct 26, 2007 | Samsung Weather Resistant Security Camera...
Looking for a manual for A Samsung SSC security system
Am not familiar with an SSC-960, there are however SVR-960 (4 versions) by Samsung.
Normally Samsung follows similar installation procedures and the differences in their model are advance features and the length of recording time. If this could be of any help, this link is a users’ manual for a 1280 hrs model. It includes installation procedures.
Alternately you can try Google for “svr 960 pdf” but when I tried it most that I can get are German language versions.
Hope this be of some help/idea.  Good luck and kind regards.
Aug 25, 2007 | Samsung Weather Resistant Security Camera...
Open Questions:
Televison & Video Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
