SOURCE: Need cylinder and cylinder head torque specifications 98 XR 250
you dont need torque specs on that just use a 1/2 inch drive with you 14mm or16mm socket hold the wratchet right at the top and tighten it as tight as you could get it like that then use wratchet in normal position and just give it a little snugg it will be perfect i have done it a million time on the same type of bikes...
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
SOURCE: Looking for an online owners manual for an XT 600
Hi there!
Can't find an owners manual but i found a parts catalog!
http://www.carlsalter.com/aaman/Yamaha%20xt600e%20%20parts%20catalogue.pdf
Hope this helps! I'd appreciate a feedback!
-levibit-
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
Short Bolts:
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
SOURCE: i can not find maintenance manual for YAMAHA XT 600 E
There is an XT 600E repair manual listed at this site. It appears to be in German. The Clymer manual covering '83-'89 is the latest from them. Haynes never made one for that model.
