Question about Refrigerators
Got flooded out and when i plug my freezer in it trips all my power off
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill! Once any electrical system gets flooded it will continue to grow corrosion and problems from then on! DUMP IT! INSURANCE COVER IT???
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Smeg Dishwasher constantly filling and tripping anti flood sensor
Fill solenoid if water constantly filling when power switched off. Level sensor in sump if just overfilling but stops when power off
Jan 19, 2018 | Smeg Washing Machines
I have the M3F72-3. It keeps tripping the breakers. When I turn the freezer off, the breakers still trip. When I unplug the freezer, the breakers are fine.
Replace breaker first. breakers get fatigued and will trip easier as they get older. most hardware stores will have the breaker, costs can be 10.00-80.00 , look on the box door for your brand (square D etc.) Trip the main breaker and use meter to make sure no power to the panel. use flat screwdriver to remove breaker where it meets the breaker next to the one your removing, don't force to hard as you may damage the good one next to the one you are removing. Use narrow straight blade or some screws have the square tip #2, #3 , loosen screw till wire comes out. reverse directions to install. if new breaker trips then your freezers electrical components drawing to many amps,,,defective, worn out or damaged compressor electrical parts.
Sep 11, 2017 | Refrigerators
Freezer trips breaker
Try turning the temp control to off. Plug the freezer in for an hour and then turn the temp control down to start the cooling.
Dec 30, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Not cooling
is the freezer plugged into a gfi outlet? outlet may have tripped.
if there is power to the unit: (light on, fan running, etc.)
a large clump of frost around the lines/ top shelf, means it could be a leaker and will need to be replaced.
a clicking, humming noise repeating every few minutes could be a compressor start relay.
if the freezer has tripped the breaker, the compressor has developed an internal short and again would have to be replaced
Oct 31, 2013 | Freezers
F1 code on my Fischer Paykal drawer dish washer . This is the flood sensor . It was. tripped when water was splashed in a plug that shares the same Circuit. How do I reset the sensor?
Not sure if the flood sensor will trip if the water is splashed into the mains plug. F1 can also occur if the power to the top drawer has failed. Flood sensor trips when water collects at the base of the dishwasher housing under the bottom drawer.
I think the problem you mention has caused the power to the top drawer to fail due to a spike when the splash on the power plug occured. This is very easy to see. Check if the display on top drawer is blank.
Nov 04, 2012 | Fisher and Paykel Dishwashers
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Kenmore freezer model C10BLEM blows circuits. I just bought it used. At original owners it worked well. I plug it in and after a couple of minutes it blows the circuit. I plugged it into the furnace...
If it is a chest freezer, almost certainly it is the compressor. Only way to check is to pull the power plug out then remove the compressor wires from the terminals then make sure it doesent touch the frame of the freezer, then plug the power back in and see if the power trips again. If not, there is the problem.
Aug 22, 2011 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Jul 01, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
