Question about Pentax AF-360 FGZ TTL Flash
*ids & 360 FGZ problem
I am a new Pentax user and very happy with the camera. I've just purchased the flash (360 FGZ) and having some problems. The flash is working fine but once in a while it freezes. Nothing works on the flash even the power switch can not be turned off. The display is on but no respond of any kind. Only thing I can do is to pull out the batteries to reset. Then it works fine for a while again. It is a annoying problem with great camera. Have anyone experience somthing like that? Should I send the flash back? What am I doing wrong?
    Master:
  • 542 Answers
I have had this problem with one of my AF360s. I think that it is the one that eventually quit, out of warranty, and cost me $80 for a new board. If once in a while is 1 out of 1,000 shots that is one thing, but if he happens almost each time that you use it you might have a dud. I would exchange it.
Posted on Sep 08, 2005
Disassemble af-360 fgz
I would not recommend disassebling a flash. the voltages inside are dangerous and it should only be done by a qualified technician.
Jun 10, 2014 | Pentax AF-360 FGZ TTL Flash
Manual af-360fgz
You may download the manual here.
Dec 11, 2011 | Pentax AF-360 FGZ TTL Flash
Vivitar lens to Pentax K-x camera adapter.
It depends which camera they were originally designed for use upon. If they are M42 lenses, then yes, but without any automatic facilities whatsoever - if not, then it is unlikely.
If you sign on to this link as a guest, you may find answers there. Pentax Forums The Ultimate Resource for Everything Pentax
May 29, 2017 | Kodak LENS ADAPTER 49 TO 55MM Lens...
I have lost my Pentax Optio S7 user instructions and would like to download another one please. karensullivan@senet.com.au
You can download the required manual from:
http://www.retrevo.com/support/Pentax-S7-Digital-Cameras-manual/id/564ci971/t/2/
On that page, click on "Get Manual" button, on the next page which opens, enter your e-mail id (even a fake e-mail id will do) and type the numbers you see in the box provided, and click "Download Now" button. Then the download will start.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 20, 2009 | Pentax Cameras
Can Film Camera lenses and Flash be used for Digital Camera Body
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
Jun 05, 2009 | Pentax MZ-60 QD 35mm SLR Camera
Problem with AF-360FGZ Flash
Yes. The *istD shutter can only provide X-sync for electronic flash up to 1/150 sec. The *istDS reaches 1/180 sec. "High speed" electronic flash is done by strobing the flash repeatedly during the period that the shutter slit is traveling across the focal plane, at th expense of cutting power output quite a bit.
Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
Flash won't fire on p-ttl mode
The AF360 can be in TTL mode until it is mounted on a P-TTL compatible camera and turned on, then it senses the camera and goes to P-TTL. However, sometimes in the past when I got TTL and it should have been PTTL it meant that either the batteries were not connected properly (I know, sounds strange, but check the battery compartment cover to make sure it is seated properly and make sure that the batteries are all in proper position), or that the AF360's contact pins were not all making proper contact with the shoe or extension. Beyond that it could be a faulty flash. You have swapped lenses and cameras with the same result, how about swapping flash? Unfortunately that may be your problem.
Pentax AF-360 FGZ TTL Flash Logo
220 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
