Question about Akai LCT2785TA 27 in. LCD Television
Vertical black bar in middle of screen
Can you help me? I'm technician Tv repairman. if you give me a tip i can follow.
thank you.
  • Akai Master
  • 5,568 Answers
I hope you are aware of how the individual pixels are controlled via an X-Y matrix. These are contained in ICs that are normally not replaceable individually by hand since they are installed by robotic machinery that is far more competent than the human hand.
The LCD itself is probably without problems but I suspect the drivers (which could be proprietary) may not be separable from the screen assembly as the panel may often be supplied by one company and the rest by the manufacturer whose name appears on the set.
Posted on Sep 29, 2008
Testimonial: "the tip was very helpful. thanks a lot"
We can hear it but the picture is very narrow in the middle if the screen
If you are referring to a horizontal line or bar, you will have to resolder the vertical IC. You may also need to replace the electrolytic capacitors that are almost next to the same IC. Now if you have a black vertical bars on the left and to the right side of the screen, you have a horizontal problem. Bad electrolytic capacitors and bad resistors in the horizontal deflection area of the TV board! Thanks for asking and give me a few hands of support!
Sep 13, 2010 | Emerson EWF2004 20" TV
Big black bar in the middle of the screen vertical
You will need to replace the Main board and I would also replace the LVDS cable that connects the main board to the LCD panel. Very easy to do, but might take about 2 hours depending on your comfort level.
You will need:
Screw Driver
LVDS cable – Part # 0500-0505-0540
Main board – Part # 3632-0652-0395
Those part numbers will work if you have a model number VOJ320F1A.
If you post the model number I will try to find the part number for you.
thanks
Aug 11, 2009 | Vizio L32 32 in. LCD HDTV
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
ILO tv black screen on top black screen on bottom with only about a 4" picture screen in middle... can you help thanks jerry
Hello dacrewof6,
This sounds like your vertical section is malfunctioning. This can be caused by the vertical drive section which connects to the yoke transformers of your CRTs. I would suggest taking the set to a qualified repair shop and having them check the vertical section of the TV.
I hope this helps
Thank you,
Shuttle83
Sep 11, 2008 | Televison & Video
Akai LCT2785TA has a black bar in the middle of the sceen.
Nine did this also. If you change the Closed Caption settings it goes away. Know not why.
Aug 28, 2008 | Akai LCT2785TA 27 in. LCD Television
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
White bar on top of screen
It only 1 bar in the middle horizontal? They Call it Vertical Line, sometime looseboard, defectiveVertical IC, Leak capacitor in vertical section. need a Repairman Tech.
Nov 19, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Vertical black bar in the middle of the screen
GREEETING FROM bELIZE YOUR SET NEEDS TO BE TAKEN TO A QUALIFIED TECH IT IS HAVING A VERTICAL PROBLEM OR A PROBLEM IN THE POWER SUPP PROBABLY A FILTER IN THE POWER SUPPLY.GOOD LUCK.
Oct 27, 2006 | Samsung TXN3071WHF 30" TV
Akai LCT2785TA 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
