Question about Akai LCT2785TA 27 in. LCD Television
Akai LCT2785TA has a black bar in the middle of the sceen.
This TV has vertical black bar in the middle . I'm not able to figure out where is the problem. I will appreciate any help.
Thank you
Nine did this also. If you change the Closed Caption settings it goes away. Know not why.
Posted on Sep 20, 2008
Akai LCT2785TA - Where is the inverter?
diagrams are not to be found for most modern sets as they only sell boards---
google the model with "parts" to locate the board which in most cases will have a photo of it---then you know what to look for
Nov 06, 2012 | Akai LCT2785TA 27 in. LCD Television
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this...
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this problem
Sep 08, 2009 | Akai LCT2785TA 27 in. LCD Television
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
Akai LCT2785TA troubleshooting
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Mar 15, 2009 | Akai LCT2785TA 27 in. LCD Television
Need setup codes for Akai KC01-B2 to run with comcast remote
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Dec 27, 2008 | Akai LCT2785TA 27 in. LCD Television
Akai LCT2785TA Capacitors blown out
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Nov 25, 2008 | Akai LCT2785TA 27 in. LCD Television
FixYa database totally screwed up!
Oddly, entering only the model number - LCT2785TA - brought up only pertainent messages although I see it often that some folks manage to enter car problems under washing machines for example so it isn't only the Fixya search facilities that are screwed up, sometimes it is an entry error.
Now, I'll see if I can find your original problem message since you didn't bother to keep it connected to your complaint.
Oct 08, 2008 | Akai LCT2785TA 27 in. LCD Television
Vertical black bar in middle of screen
I hope you are aware of how the individual pixels are controlled via an X-Y matrix. These are contained in ICs that are normally not replaceable individually by hand since they are installed by robotic machinery that is far more competent than the human hand.
The LCD itself is probably without problems but I suspect the drivers (which could be proprietary) may not be separable from the screen assembly as the panel may often be supplied by one company and the rest by the manufacturer whose name appears on the set.
Aug 28, 2008 | Akai LCT2785TA 27 in. LCD Television
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT2785TA 27 in. LCD Television Logo
101 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
